4x4 cosworth Posted February 3, 2009 Share Posted February 3, 2009 (edited) Prisliste P.E.C Cosworth Ford 2.0 Cosworth YB Big End bearing set Heavy Duty series coated 600 inc mva --------------------------------------------------------------------------------------------------------------------------------------------------- Ford 2.0 Cosworth YB Main bearing set Heavy Duty series coated 680 inc mva ----------------------------------------------------------------------------------------------------------------------------------------------------------------------- Cosworth YB 4x4 Turbo Forged piston kit6200 inc mvaPart No. 9009 Engine Type YB OE Bore size 90.83mm Bore sizes available 91mm / 91.25mm / 91.5mm / 91.75mm / 92mm / 92.5mm / 93mm Engine CC 2003.19cc / 2014.22cc / 2025.27cc / 2036.35cc / 2047.46cc / 2069.78cc / 2092.21cc Wössner Comp. ratio 8:1 OE Comp. ratio 8:1 Comp. Height 40.8 Valves per Cylinder 4 Cylinders 4 Reccomended Piston to bore clearance 0.10 ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- PEC 2.0 8V/16V Cosworth & Pinto Forged Con Rods 5200 inc mvaPart No. PECFORD2.0YB Engine Type All 2000 YB engines Inc Pinto Length C/C 128.5mm Small end Dia 24mm Big end Dia 55mm Bolts supplied? ARP Pro Wave 2000 3/8" Thread ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Cosworth YB 4x4 Turbo Wossner Forged piston & PEC Steel con rod package 11000 inc mvaPart No. 9009 Engine Type YB OE Bore size 90.83mm Bore sizes available 91mm / 91.25mm / 91.5mm / 91.75mm / 92mm / 92.5mm / 93mm Engine CC 2003.19cc / 2014.22cc / 2025.27cc / 2036.35cc / 2047.46cc / 2069.78cc / 2092.21cc Wössner Comp. ratio 8:1 OE Comp. ratio 8:1 Comp. Height 40.8 Valves per Cylinder 4 Cylinders 4 Reccomended Piston to bore clearance 0.10 Part No. PECFORD2.0YB Length C/C 128.5mm Small end Dia 24mm Big end Dia 55mm Bolts supplied? ARP Pro Wave 2000 3/8" Thread --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- PEC Billet Steel crankshaft to suit Cosworth YB and 2.0 Pinto 15000 inc mvaCrankshaft Part No : PECCRANKYBPINTO Stroke 76.95mm Fitment notes : Intended for use as a replacement crank shaft for the Ford YB Cosworth engine. Can be used in 2.0 Pinto engines, fly wheel and other fittings are as YB. -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- kan skaffe grpa høg comp stempel ogsa Part No. 9217D020 Engine Type YB OE Bore size 90.83mm Bore sizes available 91mm / 91.25mm / 91.5mm / 91.75mm / 92mm / 92.5mm / 93mm Engine CC 2003.19cc / 2014.22cc / 2025.27cc / 2036.35cc / 2047.46cc / 2069.78cc / 2092.21cc Wössner Comp. ratio 12.5:1 OE Comp. ratio 8:1 Comp. Height 40.50 Valves per Cylinder 4 Cylinders 4 Reccomended Piston to bore clearance 0.10 ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------å til desse Duratec HE 2.0 16V Turbo/Super Charged Forged piston kit Duratec HE 2.3 16V Grp.A Forged piston kitDuratec HE 2.3 16V Turbo/Super Charged Forged piston kit1.6 CVH RS TURBO Forged piston kitFord 2.0 8V ZVH Conversion Forged piston kit Ford 2.0 Pinto 8V Forged piston kit Ford Zetec 2.0 16V Silver top Turbo Forged piston kit 2.5 Focus ST Duratec I5 Turbo Forged piston kit osv!!!! samme priser som dei andre stempel setta Alle priser er inc mva,men + frakt...Forbehold om prisendringer..dette er bestillingsvarer...Rask levering909Motorsport er hovedimportør av PEC produkter i norge... Ta kontakt på Mail for bestilling Edited February 5, 2009 by 4x4 cosworth MVH 909Motorsport Send meg en e-post Powerflex foringer 909Motorsport Nettbutikk 909motorsport Link to comment Share on other sites More sharing options...
4x4 cosworth Posted February 14, 2009 Author Share Posted February 14, 2009 nettbutikk Har laget til nettbutikk so varene kan bestilles direkte dær...ca 1 ukes bestillingstid MVH 909Motorsport Send meg en e-post Powerflex foringer 909Motorsport Nettbutikk 909motorsport Link to comment Share on other sites More sharing options...
4x4 cosworth Posted February 17, 2009 Author Share Posted February 17, 2009 (edited) Oppstart tilbud!!!!!!!!!!!! http://www.websitefolder.net/909motorsport/Motordeler.asp Edited February 17, 2009 by 4x4 cosworth MVH 909Motorsport Send meg en e-post Powerflex foringer 909Motorsport Nettbutikk 909motorsport Link to comment Share on other sites More sharing options...
4x4 cosworth Posted February 26, 2009 Author Share Posted February 26, 2009 Mer varer lagt til i nettbutikken... MVH 909Motorsport Send meg en e-post Powerflex foringer 909Motorsport Nettbutikk 909motorsport Link to comment Share on other sites More sharing options...
OleK Posted February 26, 2009 Share Posted February 26, 2009 hva er den "plata" som sitter nesten ytterst på veiva der? Cosworth! Link to comment Share on other sites More sharing options...
4x4 cosworth Posted February 26, 2009 Author Share Posted February 26, 2009 hva er den "plata" som sitter nesten ytterst på veiva der? hehe..det lurte ej ogsa på...men dette er kun eit eksempel bilde av veivene dei leverer...kan skaffe bilde om noken vil ha det.... MVH 909Motorsport Send meg en e-post Powerflex foringer 909Motorsport Nettbutikk 909motorsport Link to comment Share on other sites More sharing options...
