Hei, en god dag til dere.
	Har en Kuga 2014 modell.  Diesel automat.
	To ganger har bilen fått opp en "haug" med feilkoder, gir melding(er) om at ting ikke funker og motoren stopper.
	Tror ikke jeg har feilkoder ved akkurat de stoppene, men har to bulker med feil som jeg har fått kopiert ut.
	Stoppet den 10/1 var en uke på et verksted før de transporterte  den til merkeverksted hvor den har vært siden.
	De feilsøker visst fortsatt. (Ringte etter 5 dager for å høre om de fortsatt skulle feilsøke da "kronasjen" kunne øke kraftig.)
	Legger ved de to feil filene jeg har.
	Mvh
	Ole Johnny
	Mener denne datert  22/1-22
	Car Scanner ELM OBD2
	DTC report
	Selected brand: Ford
	VIN: WF0AXXWPMAEU79470
	============1==============
	U0104(00)
	Raw code: C10400
	ECU: Engine control unit[Archive (inactive)]
	Status: Confirmed, Test failed since last DTC clear
	OBDII: Data bus, cruise control module - no communication
	============2==============
	P188C(00)
	Raw code: 188C00
	Status: Test failed since last DTC clear
	OBDII: ALL WHEEL DRIVE RELAY MODULE COMMUNICATION CIRCUIT
	============3==============
	P068A(00)
	Raw code: 068A00
	OBDII: Engine control (EC) relay - shut-off early
	============4==============
	P1139(01)
	Raw code: 113901
	Status: Test not completed since last DTC clear, Test not completed during this operation cycle
	OBDII: Water In Fuel Indicator Circuit Malfunction
	Ford: Water In Fuel Indicator Circuit Malfunction
	============5==============
	P1140(00)
	Raw code: 114000
	OBDII: Water In Fuel Condition
	Ford: Water In Fuel Condition
	============6==============
	P003A(91)
	Raw code: 003A91
	Status: Test not completed during this operation cycle
	OBDII: Turbocharger (TC)/supercharger (SC) boost pressure control A - learning limit exceeded
	============7==============
	P003A(85)
	Raw code: 003A85
	============8==============
	U2101(00)
	Raw code: E10100
	OBDII: CAN data bus - ECM incorrectly programmed
	============9==============
	P0094(00)
	Raw code: 009400
	OBDII: Fuel system leak - small leak detected
	============10==============
	P0093(00)
	Raw code: 009300
	OBDII: Fuel system leak - large leak detected
	============11==============
	P169F(00)
	Raw code: 169F00
	============12==============
	P1531(96)
	Raw code: 153196
	OBDII: Invalid Test - Accelerator Pedal Movement
	Ford: Invalid Test - Accelerator Pedal Movement
	============13==============
	P0219(00)
	Raw code: 021900
	OBDII: Engine over speed condition
	Ford: Engine Overspeed Condition
	============14==============
	P0266(92)
	Raw code: 026692
	OBDII: Cylinder 2 - contribution/balance fault
	Ford: Cylinder #2 Balance Fault
	============15==============
	P0272(92)
	Raw code: 027292
	OBDII: Cylinder 4 - contribution/balance fault
	Ford: Cylinder #4 Balance Fault
	============16==============
	P0269(92)
	Raw code: 026992
	OBDII: Cylinder 3 - contribution/balance fault
	Ford: Cylinder #3 Balance Fault
	============17==============
	P0263(92)
	Raw code: 026392
	OBDII: Cylinder 1 - contribution/balance fault
	Ford: Cylinder #1 Balance Fault
	============18==============
	P1774(02)
	Raw code: 177402
	============19==============
	P1643(64)
	Raw code: 164364
	OBDII: Fuel Pump Monitor Circuit Low Input
	Ford: Fuel Pump Monitor Circuit Low Input
	============20==============
	P1774(64)
	Raw code: 177464
	============21==============
	U0404(64)
	Raw code: C40464
	OBDII: Invalid data received - gear shift module
	============22==============
	P061C(64)
	Raw code: 061C64
	OBDII: Engine control module (ECM), engine rpm - performance problem
	============23==============
	P1304(00)
	Raw code: 130400
	OBDII: EGR Calibration High
	Ford: EGR Calibration High
	============24==============
	P1304(91)
	Raw code: 130491
	============25==============
	P1304(85)
	Raw code: 130485
	============26==============
	P1936(31)
	Raw code: 193631
	============27==============
	P164D(00)
	Raw code: 164D00
	Ford: ALL WHEEL DRIVE ID BLOCK CORRUPTED, NOT PROGRAMMED
	============28==============
	U0418(00)
	Raw code: C41800
	OBDII: Invalid data received - brake system control module
	============29==============
	U0426(00)
	Raw code: C42600
	OBDII: Invalid data received - immobilizer control module
	============30==============
	P188C(00)
	Raw code: 188C00
	============31==============
	U0104(00)
	Raw code: C10400
	============32==============
	P068A(00)
	Raw code: 068A00
	============33==============
	U0126(00)
	Raw code: C12600
	ECU: ABS/ESP[Archive (inactive)]
	OBDII: Data bus, steering position sensor control module - no communication
	============34==============
	U0401(00)
	Raw code: C40100
	OBDII: Invalid data received - engine control module (ECM)
	============35==============
	U0104(00)
	Raw code: C10400
	============36==============
	U3003(16)
	Raw code: F00316
	Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
	OBDII: Battery voltage
	============37==============
	U0437(68)
	Raw code: C43768
	OBDII: Invalid data received from differential control module, rear
	============38==============
	U0257(00)
	Raw code: C25700
	ECU: APIM
	Status: Test failed, Test failed (current drive cycle), Confirmed
	OBDII: Lost communication with front controls/display interface module
	============39==============
	U3003(16)
	Raw code: F00316
	ECU: APIM[Archive (inactive)]
	Status: Confirmed
	============40==============
	B1D38(16)
	Raw code: 9D3816
	ECU: BCM[Archive (inactive)]
	============41==============
	B1D38(19)
	Raw code: 9D3819
	============42==============
	B1088(86)
	Raw code: 908886
	============43==============
	U3003(16)
	Raw code: F00316
	============44==============
	U3008(13)
	Raw code: F00813
	OBDII: Control module - earth connection A
	============45==============
	B12BD(83)
	Raw code: 92BD83
	============46==============
	U0264(87)
	Raw code: C26487
	ECU: BCM
	Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
	OBDII: Lost communication with camera module
	============47==============
	B1390(87)
	Raw code: 939087
	Ford: Oil Temperature Sensor Circuit Short To Ground
	============48==============
	B1287(15)
	Raw code: 928715
	Ford: Servo Motor Potentiometer Airintake Left Circuit Short To Ground
	============49==============
	B1D13(11)
	Raw code: 9D1311
	============50==============
	B109B(15)
	Raw code: 909B15
	ECU: BCM
	============51==============
	B1133(11)
	Raw code: 913311
	Status: Test failed since last DTC clear, Test not completed during this operation cycle
	============52==============
	U0104(00)
	Raw code: C10400
	============53==============
	U0405(81)
	Raw code: C40581
	OBDII: Invalid data received - cruise control module
	============54==============
	U2001(87)
	Raw code: E00187
	OBDII: Audio Tape Deck Unit is Not Responding
	Ford: Audio Tape Deck Unit is Not Responding
	============55==============
	B1A57(87)
	Raw code: 9A5787
	ECU: HCM[Archive (inactive)]
	============56==============
	B1A58(87)
	Raw code: 9A5887
	============57==============
	B1A59(11)
	Raw code: 9A5911
	============58==============
	B1C98(13)
	Raw code: 9C9813
	============59==============
	B1C99(13)
	Raw code: 9C9913
	============60==============
	U0001(88)
	Raw code: C00188
	ECU: HCM
	Status: Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
	OBDII: Controller area network (CAN) data bus, high speed bus
	============61==============
	U3003(16)
	Raw code: F00316
	============62==============
	U3003(13)
	Raw code: F00313
	ECU: PSCM[Archive (inactive)]
	Status: Confirmed
	============63==============
	U0140(00)
	Raw code: C14000
	ECU: RCM[Archive (inactive)]
	OBDII: Data bus, body control module (BCM) - no communication
	============64==============
	U0253(00)
	Raw code: C25300
	OBDII: Lost communication with accessory protocol interface module
	============65==============
	U2300(64)
	Raw code: E30064
	============66==============
	U3003(16)
	Raw code: F00316
	Denne fra 31/12-22
	DTC report
	P1139(01)
	Raw code: 113901
	P1140(00)
	Raw code: 114000
	U2101(00)
	Raw code: E10100
	P0094(00)
	Raw code: 009400
	P0093(00)
	Raw code: 009300
	P169F(00)
	Raw code: 169F00
	P1531(96)
	Raw code: 153196
	P0219(00)
	Raw code: 021900
	P0605(48)
	Raw code: 060548
	OBDII: Engine control module (ECM) - ROM error
	Ford: Powertrain Control Module ROM Test Error
	P1774(02)
	Raw code: 177402
	P1643(64)
	Raw code: 164364
	P1774(64)
	Raw code: 177464
	U0404(64)
	Raw code: C40464
	P061C(64)
	Raw code: 061C64
	P1304(00)
	Raw code: 130400
	P1304(91)
	Raw code: 130491
	P1304(85)
	Raw code: 130485
	P2002(00)
	Raw code: 200200
	OBDII: Particulate trap, bank 1 - efficiency below threshold
	P1936(31)
	Raw code: 193631
	P164D(00)
	Raw code: 164D00
	U0418(00)
	Raw code: C41800
	Status: Test failed, Test failed (current drive cycle), Test not completed during this operation cycle
	U0426(00)
	Raw code: C42600
