bige Posted November 22, 2004 Posted November 22, 2004 Escort Cosworth PartsEngine Pr unitAIR FILTERS £10.00AIR FILTER TO TURBO HOSES £40.00ALTERNATORS NEW £150.00ALTERNATORS USED £90.00ALTERNATORS BRACKET STD £45.00ALTERNATORS BRACKET GRPA £90.00ALTERNATORS PULLEYS GRPA £75.00ALTERNATOR STRAP CLAMPS £25.00CRANK SENSORS £20.00DISTRIDUTOR USED £50.00DISTRIBUTOR NEW £100.00DISTRIBUTOR CAPS USED £10.00DISTRIBUTOR CAPS NEW £15.00DISTRIBUTOR ROTOR NEW £5.00DIP STICK TUBES £10.00DIP STICK £5.00ENGINE SANDWICH PLATE £25.00ENGINE LOOMS £150.00ENGINE MOUNT BRACKETS ALLOY STD £15.00ENGINE X MEMBERS NEW £100.00EXHAUST MANIFOLD GASKET £90.00EXHAUST RUBBER MOUNT £2.00EXHAUST BRACKETS £2.00EXHAUST FRONT PIPE GPN £80.00EXHAUST CENTRE £50.00EXHAUST REAR TAIL PIPES £30.00FAN BELTS £5.00FUEL FILTER NEW £20.00FUEL REG NEW STD £75.00FUEL REG NEW GRPA £125.00FUEL REG WRC £150.00FUEL REG NEW SAPH : £75.00FUEL RAIL NEW GRPN £75.00FUEL RAIL NEW STD £90.00FRONT PULLEY STD £75.00FRONT PULLEY F2 STD £75.00FRONT PULLY F2 GRPA £175.00GRPA HEAD NUTS £9.00GRPA HEAD BOLTS £15.00SHORT GPA STUDS ARP £10.00HP BOSCH FUEL PUMPS (SUBMERGED) NEW £150.00HP FUEL PUMP SENDER ASSY NEW £80.00HT LEADS SETS £50.00INLET PLENUMS GPA £100.00INJECTORS BLUE STD £35.00ING COILS NEW £20.00IDLE VALVE GREY £50.00INTERCOOLER HOSES TO PLEM £25.00INTERCOOLER HOSES TO TURBO £25.00K&N AIR FILTERS NEW £25.00LAMBA SENSORS £150.00MAP SENSORS 2.5 BAR STD £50.00MAP SENSORS 3 BAR £95.00MAP SENSORS BRACKETS £20.00OIL FILTER REMOTE £15.00OIL PRESSURE SWITCHERS £15.00OIL COOLERS £75.00SET SPARK PLUGS ACP902P £20.00SET SPARK PLUGS C55TT £20.00SETS SPARK PLUGS 57C £20.00SETS SPARK PLUGS 59 C £25.00STARTER MOTORS USED £55.00STARTER MOTORS NEW £100.00THERMOSTAT HOUSING STD £15.00THERMOSTAT HOUSING GRPA £35.00THERMOSTAT HOUSING F2 £25.00THROTTLE BODY NEW £150.00THROTTLE BODY USED £60.00THROTTLE BODY EEC 4 £100.00THROTTLE POTS SWITCH BLACK £60.00THROTTLE POTS SWITCH RED £60.00THROTTLE CABLES NEW £20.00THROTTLE PEDAL £25.00TFI £45.00TIMING BELT TENSIONERS NEW £50.00TURBO DUMP VALVE PLASTIC £15.00TURBO HEATSHIELD £50.00TURBO GRPA 247 NEW £1,250.00TURBO DRAIN PIPES £10.00TURBO DRAIN RUBBER PIPES £5.00TURBO WATER PIPES £5.00TURBO OIL FEED PIPES £20.00TURBO OVERHAUL KIT £100.00VALVE SPRING CAPS £10.00WATER PUMPS NEW RS500 £75.00WATER PUMPS NEW 4X4 £75.00WATER TEMP SWITCHERS £8.00WATER PUMP PULLEYS £25.00 GearboxA.P. CLUTCH KITS USED (PADDLE) £200.00AP CLUTCH PLATES USED £50.00AP CLUTCH COVERS £150.00CLUTCH FORKS NEW £10.00CLUTCH FORKS BOOTS £5.00GEARBOX CRADLE TO BODY BRACKETS £5.00GEARBOX CRADLES NEW £35.00GEARLEVERS NEW £35.00GEAR LEVERS LINKAGE £25.00GEAR LEVER BOOTS £5.00GRP N CLUTCH CABLES ADJ £60.00STD CLUTCH CABLE £10.00GRP N CLUTCH CABLES SPACERS £12.00GRP A CLUTCH BEARING £30.00MODIFED GRP N CLUTCH PEDALS £55.00REV LIGHT SWITCH £45.00STD CLUTCH PEDALS £45.00STANDARD RATIO GPN GEARBOXES £750.00THRUST BEARINGS £22.00SPEEDO CABLES £20.00SPEEDO DRIVES ELEC £35.00SPEEDO DRIVES MECH £15.00SPEEDO HOUSINGS £25.00SPEEDO DRIVE GEAR £20.00 PropFRONT PROPSHAFT NEW £125FRONT PROPSHAFT USED £50REAR PROPSHAFTS NEW £150REAR PROPSHAFTS USED £100RUBBER PROPSHAFT COUPLINGS £75 DiffsCROSS SHAFT NEW £90.00CROSS SHAFT USED £50.00FRONT DIFF ASSY REBUILT £150.00GRP N DIFF MOUNTS NEW £75.00GRP N DIFF MOUNTS USED £50.00GRPA DIFF MOUNTS NEW £45.00REAR DIFF ASSY 3.6 REBUILT £350.00Drive ShaftsCV GAITER KITS NEW £15.00FRONT DRIVESHAFTS NEW £175.00FRONT DRIVESHAFTS USED £125.00REAR DRIVE SHAFT DOWELS £4.00REAR DRIVESHAFTS SHORT NEW £150.00REAR DRIVESHAFTS LONG NEW £150.00REAR DRIVESHAFTS USED £100.00DRIVE SHAFTS BEAR £25.00 Front SuspensionSETS STD TCA OUTER BUSH NEW £30.00FRT ANTI ROLL BARS 28mm £50.00FRT ANTI ROLL BARS 26mm £50.00COMP ANTI ROLL CLAMPS 26mm £15.00COMP ANTI ROLL CLAMPS 28 mm £15.00ANTI ROLL CLAMPS STD £8.00COMP 26mm FRT A.R.B. RUBBERS £15.00COMP 28mm FRT A.R.B. RUBBERS £15.00FRONT HUB FLANGES NEW £50.00FRONT HUB FLANGES NEW GPA STUDS £55.00FRONT UPRIGHT COMPLETE WITH HUBS STD NEW £100.00FRONT UPRIGHTS NEW BARE £70.00COMPLETE FRONT UPRIGHTS MODIFIED USED £200.00FRT UPRIGHT TO TCA SPACERS £15.00FRT & REAR WHEEL BEARING KITS NEW £40.00INNER TCA COMP BUSHES £45.00GRP N TCA NEW £65.00GRP N TCA USED £35.00P.A.S. PUMP NEW £125.00P.A.S. PUMP USED £75.00PAS STEEL PIPE £35.00PAS ALLOY PIPE £25.00PAS HIGH PRESS PIPE £75.00PAS LOW PRESS PIPE £35.00P.A.S. BRACKET £25.00P.A.S. PULLEY STD £25.00P.A.S. PULLEY ALLOY £45.00P.A.S. RES NEW £30.00STEERING SHAFTS LOWER NEW £65.00STEERING UPPER COLUMES NEW £45.00STEERING RACKS LHD £450.00STEERING WHEELS (MOMO , SPARCO) USED £60.00STEERING WHEEL BOSS LONG £30.00STEERING RACKS BOOTS £7.00STD TRACK ROD ENDS NEW £10.00COMP TRACK ROD ENDS £25.00TRACK RODS NEW £40.00 Rear SuspensionREAR ANTI ROLL BARS 18mm £40.00REAR ANTI ROLL BARS 20mm £40.00REAR A.R.B. RUBBERS 18 mm £10.00REAR A,R,B,RUBBERS 22mm £10.00REAR A,R,B CLAMPS £4.00REAR ARM ADJUSTERS ROSE JOINTS £50.00REAR ARM ADJUSTERS £50.00REAR HUB CARRIERS NEW £75.00REAR HUB FLANGES NEW £50.00REAR HUB FLANGES WITH GRPA STUDS NEW £75.00REAR STUB SHAFTS NEW £75.00REAR STUB SHAFTS USED £50.00STD REAR ARMS NEW £100.00GPA REAR BEAM PLATES £45.00STD REAR BEAMS PLATES £30.00STD REAR BEAMS USED £90.00REAR BEAMS GRP A ROUND TYPE £350.00 Front DampersDAMPERS COMPLETE GRAVEL £250.00DAMPERS COMPLETE RACE £300.00DAMPERS COMPLETE TARMAC £250.00DAMPERS COMPLETE £300.00DAMPERS COMPLETE GRAVEL £300.00 Rear DampersDAMPERS COMPLETE £200.00DAMPERS COMPLETE £200.00DAMPERS COMPLETE RACE £250.00DAMPERS COMPLETE £200.00DAMPERS COMPLETE £200.00GPA 2WD SIERRA F/ DAMPER COMPLETE £250.002WD SIERRA DAMPERS COMPLETE £200.00 Springs FrontSPRINGS £50.0070-91-15 RED £50.0060-60-30 RED £50.00SPRINGS £50.00SPRINGS 28NM FRONT £45.00SPRINGS 30NM FRONT £45.00SPRINGS 32NM FRONT £45.00SPRINGS 44NM FRONT £45.00SPRINGS 57NM FRONT £45.00SPRINGS 65NM FRONT £45.00SPRINGS 68NM FRONT £45.00SPRINGS 68NM FRONT £45.00SPRINGS 70NM FRONT £45.00SPRINGS 70NM FRONT £45.00SPRINGS 72NM FRONT £35.00SPRINGS 72NM FRONT £35.00SPRINGS 75NM FRONT £35.00SPRINGS 30NM FRONT £35.00SPRINGS 80NM FRONT £35.00SPRINGS 85NM FRONT £45.00SPRINGS 85NM FRONT £35.00SPRINGS 140NM FRONT £45.00SPRINGS 150NM FRONT £45.00SPRINGS 90NM FRONT £45.00SPRINGS 92.5NM FRONT £45.00SPRINGS 95NM FRONT £45.00SPRINGS 100NM FRONT £45.00SPRINGS 55NM FRONT £45.00SPRINGS 110NM FRONT £45.00SPRINGS 80NM FRONT £45.00SPRINGS 85NM FRONT £45.00SPRINGS 130NM FRONT £45.00SPRINGS 210NM FRONT £45.00 SPRINGS 275LBS/FT FRONT £35.00SPRINGS 450LBS/FT FRONT £35.009" 650LB FRONT £55.00300-60-80 EIBACH FRONT £45.00C515 FRONT £45.00SPRINGS 48-66-99 FRONT £35.00SPRINGS 54-73-109 FRONT £35.00SPRINGS 300LBS FRONT £35.00SPRINGS 55NM FRONT £35.00SPRINGS FRONT £35.00SPRINGS 65NM £35.00SPRINGS 40NM 50MM £45.00SPRINGS 44NM 50MM £45.00SPRINGS 55NM 50MM £45.00SPRINGS 45NM 50MM £45.00 Springs RearSPRINGS 22NM REAR £35.00SPRINGS 26NM REAR £35.00SPRINGS 28NM REAR £35.00SPRINGS 32NM REAR £35.00SPRINGS 38NM REAR £35.00SPRINGS REAR £35.00SPRINGS 38NM REAR £35.009094093 GRAVEL REAR £35.00SPRINGS 35NM REAR £35.00SPRINGS 40NM REAR £35.00SPRINGS 45NM REAR £35.00SPRINGS 80NM £35.00SPRINGS 30-35-45 REAR £35.00SPRINGS 30NM REAR £35.00SPRINGS 72NM REAR £35.00SPRINGS 48NM REAR £35.00SPRINGS 48NM REAR £35.00SPRINGS 90NM REAR £35.00SPRINGS 36NM REAR £35.00SPRINGS 12"/180 REAR £30.009096414 GRAVEL REAR £35.00 BrakesALLOY HAND BRAKE LEVERS £45.00BRAKE ACTUATOR ASSY NEW £250.00BRAKE VALVE NEW £400.00CARBON FRONT PADS SETS £60.00CARBON REAR PADS SETS GPN NEW £45.00FRONT BRAKE CALIPER NEW £100.00ADJUSTABLE PEDAL BOXES £450.00STD PEDAL BOXES £150.00REAR BRAKE CALIPERS NEW £100.00SET FRONT DISCS NEW £50.00SET REAR DISCS NEW £50.00SETS PADGED FRONT PADS GPN £90.00SET FRONT 355mm PADS £75.00SET 285mm PADS £45.00SETS GPA 315mm PADS £55.00 GuardsALLOY REAR DIFF SHIELD NEW £75.00ALLOY REAR DIFF SHIELD USED £50.00ALLOY SUMPSHIELD NEW £250.00ALLOY SUMPSHIELD USED £200.00KEVLAR TANK GUARD USED £150.00SUMP SHIELD FRONT BARS NEW £75.00SUMP SHIELD SIDE BRACKETS NEW £100.00SUMPSHIELD X MEMBERS NEW £100.00TURRET BRACE BARS NEW £50.00TURRET BRACE BRACKETS £50.00SIDE JACKS £45.00 ElectrialHORNS NEW £50.00LHD WIPER LINKAGE NEW £50.00WIPER ARMS & BLADES NEW £20.00WIPER MOTORS £50.00IND / WIPER SWITCHES NEW £50.00VDO OIL SENDER £45.00VDO FUEL SENDER £45.00VDO FUEL GAUGE £35.00VDO OIL GAUGE £35.00 Water SystemTOP HOSES £5.00BOTTOM HOSES £6.00HEATER HOSES SMALL £3.00HEATER HOSES MED £4.00HEATER HOSES LARGE £5.00HEADER TANK TO TURBO £5.00HEATER HOSES LARGE £5.00HEATER MATRIX £50.00HEADER TANK NEW £45.00RAD FANS NEW £100.00RADIATOR C/W FANS NEW £175.00RAD FANS USED £35.00RAD FANS LARGE £50.00RAD FANS C/W CRADLE NEW £100.00RAD FANS SWITCHES £35.00STEEL PIPES ENGINE £15.00STEEL PIPES RAD £10.00RAD CAPS £10.00 BodyBONNET £100.00BONNET GRILLS NEW £50.00BUMPER LOWER GRILLS £50.00DOOR GLASS R/H NEW £75.00DOOR GLASS L/H NEW £75.00DOOR LOCK ASSY £50.00DOOR MIRRORS NEW £50.00DOORS £100.00FUEL TANK CAP £10.00HEATED REAR SCREENS NEW £50.00HEATER BOXES NEW £50.00HEATER MOTORS NEW £50.00N/S REAR QYT PANEL NEW £350.00O/S REAR QYT PANEL NEW £350.00REAR QRT GLASSES R/H NEW £45.00REAR QRT GLASSES L/H NEW £45.00SETS BONNET HINGES £10.00SETS DOOR TRIMS £75.00SETS MOULDED MUD FLAPS USED/ NEW £90.00SETS SIDE SKIRTS NEW £150.00SIDE SILL ENDS £50.00TAILGATES £50.00 LHD ESCORT COSWORTH GPA BODYSHELL £2,500.00 LampsFRONT HEADLAMPS R/H NEW £75.00FRONT HEADLAMPS L/H NEW £75.00LAMP POD COMPLETE NEW £200.00LAMP POD ONLY £60.00 Wheels5.5X13 SPOKED WHEELS £90.007X15 OZ WHEELS £55.005X16 OZ ICE WHEELS USED £65.006X16 OZ SNOW WHEELS USED £65.006X16 OZ WHEELS NEW £75.007X15 MAG CROMODORA F2 £75.007X16 SPEEDLINE GPA £65.008X16 SIERRA GPA MAG £75.006X15 COMPOMOTIVE GPA £55.00WORKSHOP TOOLS130 AMP MIG WELDER £50.00TYRE CUTTER £150.00TYRE TEMP PROBE £100.00 Focus PartsK&N AIR FILTERS £37.20EXHAUST DOWNPIPE £240.50MAP SENSOR BRACKET £10.62WATER HOSE TOP £6.66WATER HOSE MODEM £7.42TURBO 90deg PLENUM ELBOW £32.14ALLOY BREATHER TANKS £188.50TURBO HOSE 90deg ELBOW £43.94100mm ALLOY TURBO JOINERS £16.50TURBO COMP/HOUSEING HOSE £31.84THROTTLE HOUSEING ADAPTOR £55.38TURBO WATER PIPE £11.78ALLOY JOINER £11.50TURBO TO INTERCOOLER ALLOY PIPE £62.50T/HOUSING BRACKET INSULATOR £1.4545deg TURBO TO AIR FILTER HOSE £42.82TURBO/AIR FILTER REDUCER £24.81BATTERY TRAY MOUNTING BOBINS £7.50MODIFIED BATTERY TRAYS £80.25FOCUS RALLY SUMP GUARD SUPPORT BRACKET £75.23FOCUS RALLY SUMP GUARD SUPPORT BAR £150.00EXHAUST REAR BOX £85.50SET GEAR CHANGE CABLES £95.20T190 /250 BONNET VENTS £34.60MODIFIED FUEL PUMP £145.50AIR BAG KIT £750.90T250 QUAIFE SEQUENTIAL GEAR LEVER £450.00PAIR STD FRONT UPRIGHTS COMPLETE WITH BRAKES £200.00PAIR SIDE SILLS £45.20STD GEAR LEVER £37.80T250 ( FOCUS RS )FRONT BUMPER NEW £200.00 GPA PARTS355 X 28 MM FRONT DISCS NEW £200.00355 X 28 MM FRONT BREMBO DISCS USED £150.00355 X 28MM FRONT AP DISCS USED £150.00310 X 28 MM FRONT AP DISCS USED £80.00ALLOY AP RADIAL MOUNT BRACKETS £25.00TRACK ROD ENDS £10.00STEERING RACK YOKES £25.00TRACK ROD ENDS ROSE JOINTS £35.00ALLOY WHEEL NUTS £5.00GPA ESCORT WHEEL STUDS £5.007 SPEED FF CLUTCH FORK AND BEARING £100.007 SPEED FF DOG RINGS £60.007 SPEED FF GEARS £70.00ALTENATOR HEAT SHIELDS £25.00 GPA ESCORT PARTSEngine PRICEAIR FILTER BOXERS £50.00ALTERNATORS USED £150.00ALTERNATORS BRACKET GRPA £60.00ALTERNATORS PULLEYS GRPA £60.00ENGINE MOUNTS STD £10.00ENGINE X MEMBERS £35.00EXHAUST FRONT PIPE £55.00EXHAUST CENTRE £45.00EXHAUST REAR TAIL PIPES £55.00OIL FILTER REMOTE £150.00STARTER MOTORS USED £55.00TIMING BELT COVERS £5.00TURBO HEATSHIELD £25.00SUMP BAFFLES £30.00SLANTED RADIATOR £350.00LHD STEERING RACK £750.00 9 " REAR C/W PINION 4.4 £400.00 Drive ShaftsFRONT ENDS GRP A £75.00FRONT DRIVESHAFTS GPA £250.00REAR DRIVESHAFTS USED £250.00 Steering-Front SuspensionFRT ANTI ROLL BARS GPA £150.00ANTI ROLL BARS GPA BLADE £75.00FRONT HUB FLANGES USED £100.00P.A.S. PUMP USED £100.00P.A.S. BRACKET £80.00P.A.S. PULLEY ALLOY £45.00STEERING SHAFTS LOWER NEW £25.00STEERING RACKS DRUM STICKS £25.00GPA DRUM STICKS £150.00 GPA RS 500 PARTS GP A RADIATOR £250.00STEERING RACK £350.00ALLOY FRONT TOP MOUNTS £50.00FRONT DAMPERS £200.00STEERING COLUMBE £150.00REAR PROPSHAFT £50.00REAR DRIVE SHAFTS £90.00REAR DAMPER £200.00FRONT ROLL BAR £150.00REAR ROLL BAR £150.00 SAPPHIRE GPA APRTSROLLING SHELL £1,500.00MOUNTUNE ENGINE £4,500.00RADIATOR £200.00INTERCOOLER £100.00THICK WALL FRONT DIFF £750.00STEERING RACK £350.00SUMP GUARD £100.00ALLOY TCA £250.00COMP STRUTS £150.00ALLOY FRONT UPRIGHTS £450.00GPA FRONT SHAFTS £250.00315MM AP FRONT BRAKES £700.00FRONT DAMPERS £200.00FRONT TOP MOUNTS £50.00STRUT BRACE £50.00ECU £350.00SPORT GEAR BOX £3,000.00FRONT PROP £45.00REAR PROP £55.00GPA REAR BEAM £350.00GPA REAR MAG ARMS £450.009" REAR DIFF £3,000.00REAR DRIVE SHATFS £250.00EXHAUST SYSTEM £100.00REAR DAMPERS £200.00FUEL PUMP £80.00REAR TOE LINKS £100.00285 MM AP REAR BRAKES £700.00 ESCORT GPA PARTSRADIATOR £350.00LHD STEERING RACK £750.00 all parts are plus vat_________________ATMsport LTD, Kelverdon , Essex, specialists in motorsport parts, e-mail sales@atmsport.com, web page www.atmsport.com tel 01376 585125all prices are plus VAT Last edited by andyt6762 on Mon Oct 04, 2004 10:40 am; edited 2 times in totalBack to top View user's profile Send private message
bige Posted November 23, 2004 Author Posted November 23, 2004 ??? tenkte det mere som info om prisene som er ute og går ......
RsTurboTaule Posted November 24, 2004 Posted November 24, 2004 Denne her kunne trengt noen nye deler kansje.. hehe 88 Escort RSTurbo
