rattlesnake Posted May 7, 2009 Posted May 7, 2009 ønsker som overskriften viser å kjøpe 4 komplette 4x4 stempler (mahle) i 1mm overdim altså til 91.80 boring fint om noen har..haster nåes på tlf 99375148
4x4 cosworth Posted May 7, 2009 Posted May 7, 2009 ønsker som overskriften viser å kjøpe 4 komplette 4x4 stempler (mahle) i 1mm overdim altså til 91.80 boring fint om noen har..haster nåes på tlf 99375148 Hei Kan levere desse nye for 5875 inc mva + frakt Part No. 9009 Engine Type YB OE Bore size 90.83mm Bore sizes available 91mm / 91.25mm / 91.5mm / 91.75mm / 92mm / 92.5mm / 93mm Engine CC 2003.19cc / 2014.22cc / 2025.27cc / 2036.35cc / 2047.46cc / 2069.78cc / 2092.21cc Wössner Comp. ratio 8:1 OE Comp. ratio 8:1 Comp. Height 40.8 Valves per Cylinder 4 Cylinders 4 Reccomended Piston to bore clearance 0.10 MVH 909Motorsport Send meg en e-post Powerflex foringer 909Motorsport Nettbutikk 909motorsport
rattlesnake Posted May 7, 2009 Author Posted May 7, 2009 Hei Kan levere desse nye for 5875 inc mva + frakt Part No. 9009 Engine Type YB OE Bore size 90.83mm Bore sizes available 91mm / 91.25mm / 91.5mm / 91.75mm / 92mm / 92.5mm / 93mm Engine CC 2003.19cc / 2014.22cc / 2025.27cc / 2036.35cc / 2047.46cc / 2069.78cc / 2092.21cc Wössner Comp. ratio 8:1 OE Comp. ratio 8:1 Comp. Height 40.8 Valves per Cylinder 4 Cylinders 4 Reccomended Piston to bore clearance 0.10 okey..men hvor fort da?
4x4 cosworth Posted May 8, 2009 Posted May 8, 2009 okey..men hvor fort da? Hei Beklager sent svar...det tar ca 1 uke... MVH 909Motorsport Send meg en e-post Powerflex foringer 909Motorsport Nettbutikk 909motorsport
