86cosworth Posted June 15, 2009 Share Posted June 15, 2009 Hei. har 86 cosworth, og har jo org L1, men hvordan kan jeg finne ut det? Har sjekka nr ut på hjernen idag, og der står det : IAW 045 12V DC WD 45.01-1C . 60 MED 503C 64834312 Sier desse talla dere noe ? på forhånd takk. Hans Christian 1986 Ford Sierra Cosworth, moonstoneblue *orginal* 1985 Ford Sierra 2.0L 3dørs *skal bygges om med tiden* Link to comment Share on other sites More sharing options...
Kverna Posted June 15, 2009 Share Posted June 15, 2009 Try L1, as yours is WD4501 ic 60 med 503c is L1.So it should have flanges which secure it to the metal bracket behind the glovebox, and a YELLOW screw for the CO adjust ?, L6 have a WHITE screw and are different number. http://www.bigturbo.co.uk/main1.htm Min fotoblogg Link to comment Share on other sites More sharing options...
86cosworth Posted June 15, 2009 Author Share Posted June 15, 2009 Takk 1986 Ford Sierra Cosworth, moonstoneblue *orginal* 1985 Ford Sierra 2.0L 3dørs *skal bygges om med tiden* Link to comment Share on other sites More sharing options...
Kverna Posted June 15, 2009 Share Posted June 15, 2009 Superkverna, Toooo the rescueeeeee *swoooooosh* Min fotoblogg Link to comment Share on other sites More sharing options...
86cosworth Posted June 15, 2009 Author Share Posted June 15, 2009 hehehehe 1986 Ford Sierra Cosworth, moonstoneblue *orginal* 1985 Ford Sierra 2.0L 3dørs *skal bygges om med tiden* Link to comment Share on other sites More sharing options...
Cossyman85 Posted June 15, 2009 Share Posted June 15, 2009 Superkverna, Toooo the rescueeeeee *swoooooosh* ble du litt medrivi i filmen hehe Link to comment Share on other sites More sharing options...
