Mexico-Rally Posted August 29, 2016 Share Posted August 29, 2016 Kjøpte stikkaksler med feil spline. Begge er som nye. Nypris er £120 + frakt og moms. Selger begge for 900kr samlet. Kan sendes i hele Norge eller hentes i Oslo.Flanger må kjøpes separat. (3J driveline eller Burton)Fra hjemmeside til produsent:Group 1 halfshafts are two piece, with separate shaft and flange. An integral flange is used to retain the wheel bearing rather than the usual bearing collar which often comes away. These differ from others on the market by the use a coned washer and lock nut design to eliminate the common problem of shaft nuts coming undone under hard cornering. 16 tooth spline (std English Escort). Selv har jeg tidligere brukt Quaife. Disse holder høyere kvalitet og er letter når man må justere offset. (3J Driveline) Selger: Thomas Berve, 95918451 , Oslo Link to comment Share on other sites More sharing options...
Mexico-Rally Posted September 6, 2016 Author Share Posted September 6, 2016 Solgt! Link to comment Share on other sites More sharing options...
