Skal se ut ca som her: Brand Pioneer Model TS-W255DVC Description Range / type Subwoofer Typical use Car Recomended enclosure Series Manufacturer Order nr Production status Undeterm. Nom. diamerer [inch] 10 Vas [Liters] 24,881 Qts 0,351 Qes 0,359 Qms 15,28 Fs [Hz] 35 Sensitivity [dB] 87 Max Power [W] 350 Power definition Nominal Lower freq [Hz] Upper freq [Hz] Rec. Filter freq [Hz] xmax [mm] 11,2 Moving mass [g] 115,66 Disp area [m2] 0,0314 Disp Vol [cm3] xdamage [mm] Air gap [mm] 10 Coil height [mm] 32,4 Coil diameter [mm] 49 Cms [mm/N] 0,1767 Rms [N*s/m] 1,668 Magnet weight [gr] 2,1 Magnet height [mm] Magnet diameter [mm] Magnet material - Re [ohm] 3 Z [ohm] 4 L [mH] 2,254 Bl [Tm] 14,965 Magnetic flux [Wb] Flux density [T] Outer diam. [mm] Bolt circle [mm] Nr of bolts [Nr] Cutout [mm] Weight [Kg] Height [mm] Depth [mm] Driver volume [Liters] 1,58
