Takker:) kopiert tekst fra Motorsport Developments sine sider hva 380 innebærer, kjører med t34 turbo med 360 lager, pluss har jo bytte til 6pucka clutch og forsterket trykkplate:)  380+bhp "For those of you with either a Large Turbo Escort Cosworth or a retro-fitted T34.63 turbocharger, this in our eyes is the ultimate fast road package! After hundreds of hours of development, the results are hard to believe considering they can be achieved on a standard engine! With the fitment of larger fuel injectors (Siemens 55lb Blacks), a 3 Bar MAP Sensor to accurately read higher boost pressures and a stronger actuator to increase the boost pressure. This package is a guaranteed smile raiser! Runs a 33psi peak boost pressure falling slowly through the rev range to your new 7600rpm rev limiter!   The package includes the supply and fitment of:   380bhp Evolution Chip 55lb or larger Fuel Injectors A 3 bar map sensor (To be supplied by yourself as they are NLA) A -34 Actuator A Full Setup inc. Fuel, Boost & Detonation Check Under Load   This package does put some extra strain on the engine and to ensure reliability we do recommend the head gasket is upgraded to a multi layer item. An oil breather system and up rated intercooler is essential on this package as well."  Sku gjerne hatt en fastback i garasjen;) litt usikker på akkurat det.. Hvordan finner jeg ut det?
