Det går fint ann å programmere nøklen igjen. Gjort det flere ganger.. 1. Fasten the safety belts and close all doors to make sure that conflicting chimes do not sound during programming. 2. Turn the ignition switch from position I to position II four times within six seconds. 3. Turn the ignition switch to position I. An audible chime will be heard to indicate that learning mode is enabled. 4. Press and hold one of the buttons on the remote transmitter until a chime sounds. This indicates the remote transmitter code has been successfully received. 5. Repeat step 4, within 10 seconds, for any other transmitters you have. De trenger ikke å stå i tenningslåsen. 6. Wait 10 seconds or turn the ignition switch to position II to exit learning mode. 7. Test all the programmed remote transmitters, by activating and deactivating the locking/unlocking functions
