morty999 Posted October 8, 2006 Posted October 8, 2006 (edited) selger 4 orginale is topper4 stk gasser topperAudi s2 dyser 1200krL8 hjerne med std chip 2000kr (solgt)escort cossie IC 1500kr4x4 cossie radiator med vifter (1 deff) 1000krflere is hjerner (86mod)fordelere (motorcraft)luftmengdemålereIS veiv4 stk IS Innsug++ har også MYE mer deler til is.. bare å spørre Morten97623279 Edited October 29, 2006 by morty999
Guest meino Posted October 8, 2006 Posted October 8, 2006 mye hadde du tenkt deg i pris for en 86? hvilken stand er dem i?
morty999 Posted October 8, 2006 Author Posted October 8, 2006 (edited) dobbelpost... Edited October 8, 2006 by morty999
morty999 Posted October 8, 2006 Author Posted October 8, 2006 (edited) 28,6kg med vippere hehe EDIT: det er faktisk helt riktig ifølge posten (sendt før) Edited October 8, 2006 by morty999
Guest meino Posted October 8, 2006 Posted October 8, 2006 da blir det vel å koste noe sykt å få sendt den?
morty999 Posted October 8, 2006 Author Posted October 8, 2006 298kr el no mener jeg å huske... ekke helt sikker
Guest meino Posted October 8, 2006 Posted October 8, 2006 (edited) er ventilitettningene gåen? Edited October 8, 2006 by meino
Guest meino Posted October 8, 2006 Posted October 8, 2006 (edited) æsj dobbelpost Edited October 8, 2006 by meino
laerdh Posted October 8, 2006 Posted October 8, 2006 Litt OT, men det koster ikke mye å sende det i posten med de nye pakkene som erstatter for norgespakkene. Der er det ikke vekttillegg. Du kan fylle pakken med bly, og likevel betale det samme. Smartpost heter det vel. Så da vet du det! Hehe '91 Sierra Sedan IST - Haltech E6X, Garrett T3, Gule dyser, 3" eksos, 3bar map - Ny motor på gang
morty999 Posted October 9, 2006 Author Posted October 9, 2006 du må nok regne med å bytte ventiltettninger ja.. hehe vet ikke åssen disse er..
Guest pzycho Posted October 9, 2006 Posted October 9, 2006 gjør som meg morten sett den bare halveis på vekta, så koster frakta en 100lapp mindre :P
morty999 Posted October 16, 2006 Author Posted October 16, 2006 (edited) bump Edited October 16, 2006 by morty999
Guest Ford-Babe Posted October 16, 2006 Posted October 16, 2006 Norgespakken kan fylles med 30kg den største,til ca 140kr, husk masse tape rundt pakken,ellers kan noen få en overaskelse om toppen vil ut på egen hånd
morty999 Posted October 22, 2006 Author Posted October 22, 2006 veide en topp i går.. 20.2 kg uten kam. vippere og ventiler.. dvs en REIN topp... kan tenke meg att ventilene veir ca 2 kg..
tuszi Posted October 22, 2006 Posted October 22, 2006 (edited) smartpost med oppkrav så lenge pakka er innafor måla er 177 kr så ekke så dyrtL=120 b=60 h=60. så går den innafor det blir det bare 177 Edited October 22, 2006 by tuszi
Lars Magne Posted October 28, 2006 Posted October 28, 2006 Har ikkje noken eks manifold`er til turbo då ? <1978 Ford Taunus 2,0 Base
morty999 Posted October 28, 2006 Author Posted October 28, 2006 hehe.. de jeg har selv skal jeg bruke.. hehe
