Guest Alex_86 Posted October 12, 2006 Posted October 12, 2006 Den 1.9 liter blokka til escort. noen som har info om den eller? hvilken er det? hvilken års mod? snakker om blokka fra usa escorten ja Description (revised) Included is the engine block, crankshaft, oil pan, flywheel, exhaust manifold, oil pump, crankshaft pulley, dip stick, oil pressure sensor, power steering pump with its pulley and mount, drive belt tension pulley, drive belt pulley, power brake master cylinder, cooling system water pump, cooling system fan, third brake light, shift-to-park cable, speedometer cable, shifter console panel, right front fender, tail lights, right & left brake light units, intake air flow sensor unit, sun visor clips, and emergency brake handle. The items were removed from a 93 Ford Escort with a 1.9 liter, 8 valve, fuel injected, 4 cylinder engine, in good, smooth running condition.
packs Posted October 12, 2006 Posted October 12, 2006 cvh motorenehttp://en.wikipedia.org/wiki/Ford_CVH_engine The CVH was bumped up to 1.9 L for the North American 1986 model year Escort. Bore was now 82 mm (3.230 in) and stroke was up as well to 88 mm (3.465 in). This stroke length would be used in all future CVH engines, and continued into the Zeta engine which replaced it. This long stroke necessitated a raised engine block deck, a design also shared with later units. Output was 86 hp (64 kW) and 100 ft.lbf (136 Nm). Electronic fuel injection and hemispherical "hemi" combustion chambers were added for 1987's Escort GT, bumping output to 108 hp (81 kW) and 114 ft.lbf (155 Nm). The second generation of American Escort got sequential EFI for 1991-1996, but power and torque was little changed at 88 hp (66 kW) and 108 ft.lbf (146 Nm) respectively. amrikanske ford escort:http://en.wikipedia.org/wiki/Ford_Escort_%...rth_American%29 hjalp dette noe? ------------------------------------------------------------------- Escort MK5a, 91mod, 2.0 zetec
Guest Alex_86 Posted October 12, 2006 Posted October 12, 2006 japp hjalp litr, men hmmm er det samme all the way.. og er det cvh den å. eller och?
RsturboS2 Posted October 12, 2006 Posted October 12, 2006 japp hjalp litr, men hmmm er det samme all the way.. og er det cvh den å. eller och? alex.. : The CVH was bumped up to 1.9 L for the North American 1986 model year Escort. tror du fikk svaret ditt der.. hehe Profesjonell rotekoppp ute på bedringens veg men får alltid motorstopp.I got Adhd whats your excuse ?
