Miguel_ Posted September 17, 2008 Share Posted September 17, 2008 HeiHå.. Skulle monter ei cossie 2wd bakstilling på min mk1 5dørs IS, men foringa i bærebrua er får tykk, så skruene fra den gammle bakstillinga blir for korte. Er det da bare å bruke skruer fra Cossie eller må man gjøre noe annet ? MVH Mikael Sierra 2.0iS Link to comment Share on other sites More sharing options...
2.8turbo Posted September 17, 2008 Share Posted September 17, 2008 bruke alt fra cøss ja:) ESCORT RST/ Sierra IST Link to comment Share on other sites More sharing options...
Miguel_ Posted September 17, 2008 Author Share Posted September 17, 2008 ok..takk Sierra 2.0iS Link to comment Share on other sites More sharing options...
Guest Ford Gnomen Posted September 19, 2008 Share Posted September 19, 2008 Er det den store du snakker om? Må enten bruker lenger bolt når en monterer eller presse den opp med jekk. Link to comment Share on other sites More sharing options...
megamann89 Posted September 21, 2008 Share Posted September 21, 2008 (edited) Hvis det er den store det er snakk om, så bruk et gjenge stag og skru foringene sammen,slik at de blir presset opp. Sett deretter jekken under bærebrua og skru inn den gamle bolten Edited September 21, 2008 by megamann89 Link to comment Share on other sites More sharing options...
