tomnsr Posted July 23, 2009 Posted July 23, 2009 Hei, har fått svar på søknaden min til biltilsynet nåJeg søkte om å få montere 2,9 8v v6 ifra sierra, men fikk ikke godkjent søknaden med mindre jeg skaffet dokumentasjon på at Taunus er lever med 3,0 i Ford Cortina Perana. Noen som har tekniske dokumenter ifra denne modellen? eventuelt noe annet hjelpsomt?Slik jeg tolker søknaden skal det være mulig å godkjenne bilen med 2,9 dersom jeg skaffer dokumentet. Takk for svar! mvh Tom. Et kjapt søk på nettet så fant jeg dette: The Ford Cortina is a mid-sized family car built by Ford of Britain in various guises from 1962 to 1982. The Cortina was Ford's mass-market mid-sized car and sold in enormous numbers, making it common on British roads. It was replaced in 1982 by the Ford Sierra. In other markets, particularly Asia and Australia, it was replaced by the Mazda 626-based Ford Telstar, though Ford New Zealand did import British-made CKD kits of the Ford Sierra estate for local assembly from 1984. The Cortina was produced in five generations (Mark I through to Mark V, although officially the last one was called the Cortina 80) from 1962 until 1982. From 1970 onward, the TC model, in in'73 the TD model, then the TE (76) and TF (or '80). From the 1976 model on (mk4) it was identical to the German-market Ford Taunus (being built on the same platform) From 1300 cc Kent engined OHV engines in the UK, to 3000cc XLE models in south africa it proved a very flexible platform with the left hand drive taunus coming in a very attractive fast back 2 door, most taunus were powered by V6 cologne powerplants of smaller size than those in the UK, preffering the smooth 2000cc V6 to a 4 CYL., as opposed to kent (OHV) or Pinto (OHC)which were the uk engines from the TC onwards. Men ingen ting av dette kan vel brukes som bevis...Skulle hatt noen tekniske data på bremser osv!
turbodohc Posted July 24, 2009 Posted July 24, 2009 (edited) Fant no her da Ford Cortina 3000GT And XLE 1973 to 1977 Tipe: V6 OHV 2994 cmBore and stroke: 93.67x72.42 mmPower (max): 117.2 kw @ 5000 RpmTorque (max): 257 Nm @ 3000RpmCompression ratio: 8.9:1Oil pressure: 300 KpaFiring order: 1R-4L-2R-5L-3R-6L No 1 at R/front. Her står det litt om Ford cortina XR6 http://www.moby302.co.za/ford/1983_ford_co...xr6_x-ocet.html Litt mere Cortina Perana V6 The first "official" car produced by Basil Green was the Cortina perana. It was sold by though Ford dealerships.. According to www.perana.org the car was based on the Mk2 Ford Cortina GT. The drive train was up-rated using the Ford Zephyr 3 litre V6 (Essex) engine, Lotus Cortina gearbox and Salisbury differential. http://perana.org/cortinamk2.php Edited July 24, 2009 by turbodohc
"Lakkelars" Posted September 8, 2011 Posted September 8, 2011 ser tråden er gammel men hva skjedde med dette? Mvh Morten 2005 focus 2.0 sport combi MS design1995 mondeo 2.0 4x4 SOLGT 3 stk 1996 mondeo delebiler HUGD1993 corolla 1,3 SPIKER! KJØPES PÅ COOP OBS
