ojt Posted February 22, 2011 Share Posted February 22, 2011 Kjøpte en ecu for en stund tilbake, den skulle være til vingebil (L1) alt som står på den er. IAW 045 H 88 BB 12A297AA PI 010 SERIAL NO ?7510 Er dette L1? Link to comment Share on other sites More sharing options...
Tommen Posted February 22, 2011 Share Posted February 22, 2011 Er co skruen hvit eller gul? The Golden era.. 1986-1987-1988 Link to comment Share on other sites More sharing options...
fiesta_xr2i Posted February 22, 2011 Share Posted February 22, 2011 mener det er 45=L1 , 46=L6 , 48=L8 ?? 2012 Focus 1.0 Ecoboost Stv 125 hk X 2004 Focus ST 170 Imperial Blue X 87/91 sierra cosworth 4x4 stage 3 X 01 mondeo 2,0 tdi stv 115hk X 92 fiesta xr2i 1,8 16v (RS1800) X 88 sierra 2,0 sedan X 90 sierra 2,0i combi Link to comment Share on other sites More sharing options...
skogly Posted February 22, 2011 Share Posted February 22, 2011 mener det er 45=L1 , 46=L6 , 48=L8 ?? feil.det er som følgende Level 1 ecu - WD45.01 IAW045 vingebil Level 6 ecu - W45.06 IAW045 sedan 2wd Level 8 ecu - WD48.08 IAW048/01 eller WD48.08 IAW048/02 sedan 4wd P 8 ecu - IAW048/P8 escort cosworth 86 Sierra RS Cosworth75 Ford Taunus 2d 2,0ist "under construction"79 Mercedes 309d10 Renault Laguna12 Ford Mondeo Titanium 2.0tdci Link to comment Share on other sites More sharing options...
ojt Posted February 22, 2011 Author Share Posted February 22, 2011 Er co skruen hvit eller gul? Den er gul Link to comment Share on other sites More sharing options...
skogly Posted February 22, 2011 Share Posted February 22, 2011 Da er det L1 86 Sierra RS Cosworth75 Ford Taunus 2d 2,0ist "under construction"79 Mercedes 309d10 Renault Laguna12 Ford Mondeo Titanium 2.0tdci Link to comment Share on other sites More sharing options...
ojt Posted February 23, 2011 Author Share Posted February 23, 2011 Da er det L1 Fint, takk for hjelpen Link to comment Share on other sites More sharing options...
bige Posted February 23, 2011 Share Posted February 23, 2011 ECU types used in Sierra (RS) Cosworth:All type of Sierra (RS) Cosworth use a Weber Marelli type of ECU (Engine Control Unit or motormanagement) however, these ECU's have changed over the years as demands grew and computer technology improved.Although, as far as known, all ECU's use the same connector pin-out (und thus can be electrically interchanged) one can not use for instance the latest ECU on the earliest Cosworth. This is because the ECU is fully "tuned" to the engine characteristics which have dramatically changed over the years. The latest ECU's also use input from several additional sensors which are not available in older models.Here is an overview of ECU's used and how to recognise them: Level 1:Used on the RWD hatchback RS Cosworth, has 64Kb of memory. Can be recognised by the mounting flange on the front face and a yellow CO adjustment screw.Level 6:Used on the RWD sedan (RS) Cosworth, has the same capabilities as the level 1 model but uses totally different electronics. That's why Level 1 and Level 6 chips can not be interchanged.Can be recognised by the mounting flange on the front face (like the Level 1) and a white CO adjustment screw (Level 1 has a yellow one).Level 8:Used on the 4x4 sedan (RS) Cosworth, has twice the memory storage capacity (128Kb instead of 64Kb) as Level 1 and Level 6. That's why chips can not be interchanged.Level 8 was available in 2 type since the engine in the 4x4 was available with and without hego-sensor (i.e. with and without catalytic convertor).Can be recognised by not having mounting flanges and a green or red label with WD48.08.The one with the green label and second code IAW048/01 is for the catalytic convertor (US83) model.The one with the red label and second code IAW048/02 is for the non catalytic convertor (15/04) model.It is uncertain if units/chips can be interchanged between red and green types/engines.There are also Weber Marelli P8 (no flanges, white label IAW48/P8) and Ford EECIV (totally different from Weber Marelli, central bolt to hold connector) ECU's around. These are however only intended for use on a Escort RS Cosworth but you might find them in some motorsport Sierra's (RS) Co Link to comment Share on other sites More sharing options...
lowman Posted May 7, 2019 Share Posted May 7, 2019 Tenkte bare å fyre opp denne tråden engang til.Er det noen her som kan identifisere en original chip i en L1 hjerne?Har en L1 hjerne som jeg skal ha i min vingebil...og denne skal det stå ett steg en chip i.Så jeg har funnet en kar som selger ett tilsynelatende original chip til L1...Er det noe måte å se dette på ? Dette er chipet jeg har tilbud om Link to comment Share on other sites More sharing options...
