Veldig godt tips den trakten der fra biltema. Det hele gikk sølefritt :-) Har byttet dieselfilteret. Helt på en flaske dyserens. Fylt opp med diesel i filteret. Kjørt motor i 10-15 sek. Nå lar jeg den stå til i morgen tidlig. Jeg koblet til ForSCan med obd-usbadapteren. Men jeg syns det var vanskelig å bli helt klok på den. Hvordan bytter man feks adresse i computeren om jeg må bytte dyse nr 3? Her er logfilene jeg tok ut fra ForScan:: #####configuration###### Interface: Type: FTDI #1:A5005VF1, 38400 kbpsAdapter: ELM327 v1.4Min.delay: 16 ms ( Good) Vehicle: Model: Ford MondeoEngine: Duratorq-Turbo Diesel Common Rail InjectionCapacity: 2.0LYear: 2001 MYVIN: WF0WXXGBBW4R24904 PCM - Powertrain Control ModulePart number: 4S71JCCalibration: 4S71-12K532-XC ICU - injector control unit HEC - Hybrid Electronic ClusterPart number: 3S7T-10849-JCSoftware version: v1 2002-12-20 RCM - Restraint Control ModulePart number: 4S7T-14B056-ABSoftware version: v3 2002-06-26 GEM - Generic Electronic ModulePart number: 3S7T-15K600-TBSoftware version: 2003-04-01 ABS - Anti-Lock Brake / Traction Control ModulePart number: 3S71-2C405-ACSoftware version: 2003-06-27 ########Utlest log fra DTC:##### ===PCM DTC P1000===Code: P1000 - On-Board Diagnostic (OBD) Systems Readiness Test Not Complete Module: Powertrain Control Module Diagnostic Trouble Code details EOBD Systems Readiness Test Not Complete This DTC may be caused by : Some or all of the EOBD monitors not being correctly completed. EOBD monitors not complete since last DTC clear. To resolve, run engine from cold through warm up cycle to allow monitors to complete successfully. do not replace the module when this DTC is set if this is the only DTC present, return the vehicle to the customer, the DTC will clear under normal operating conditions For further diagnostic information refer to the appropriate section of eTIS. ===END PCM DTC P1000=== ===PCM DTC P0251===Code: P0251 - Injector pump fuel metering control malfunction Module: Powertrain Control Module Diagnostic Trouble Code details Injector pump fuel metering control malfunction This DTC may be caused by : There is a fuel rail pressure control fault. no fuel in tank Restriction between fuel pump and fuel tank Blocked fuel filter. Blocked kinked or crushed fuel lines Fuel Metering Control Valve/Wiring Injector fault For additional information refer to: TSB No. 46/2005 Perform the Fuel Pressure and Leakback test. FIP malfunction ===END PCM DTC P0251=== ===PCM DTC P2338===Code: P2338 - Cylinder 3 knock control limit attained Module: Powertrain Control Module Diagnostic Trouble Code details Cylinder 3 knock control limit attained This DTC may be caused by : One or more injectors have reached their adaptive limit. Check the PCM for the latest calibration. Enter the correct injector correction factor as it is read counter-clockwise from the head of the injector. Clear fault codes Road test the vehicle and run the diagnostic again. If the %(DTC) are still present: Renew the injector in cylinder 3. When an injector is renewed the injector configuration routine must be carried out. ===END PCM DTC P2338=== ===HEC DTC None===Successfull DTC reading, no error codes found Module: Hybrid Electronic Cluster ===END HEC DTC None=== ===RCM DTC None===Successfull DTC reading, no error codes found Module: Restraint Control Module ===END RCM DTC None=== ===GEM DTC None===Successfull DTC reading, no error codes found Module: Generic Electronic Module ===END GEM DTC None=== ===ABS DTC U2202===Code: U2202 - CAN communication bus fault Module: Anti-Lock Brake / Traction Control Module Diagnostic Trouble Code details Communication fault between the ABS ECU and the PCM This code is set when a fault has been detected on the CAN bus. This code is set when the ABS module does not receive valid CAN data from the PCM This code is set when the ABS module does not receive valid configuration CAN data from the PCM. Run engine diagnostic This DTC may be caused by : Open circuit Damaged or contaminated connector Short circuit Check the CAN bus and terminating resistor (60 ohm) at the OBD connector. Disconnect the ABS connector and check the CAN lines between ABS module and the OBD connector. Note: DTCs that start with 'U' are faults which occur during module-to-module communication. Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle. ===END ABS DTC U2202===
