Malmstone
Everything posted by Malmstone
*bump*
Motor • Shortblock: Cosworth 200 • Pistons: Cp pistons with Total seal rings • Conrods: Cosworth shoot peened • Conrod bolts: Arp • Oil pump: Cosworth High pressure • Weighted and balanced • Headbolts: Arp • Head: Ported,Dual springs • Bd16+ Inlet cam/Bd15 Exhaust cam • Vernier pulleys: Piper • Inlet plenum: Cobramannen 3" throttle body • Injectors: MSD 788cc • Head gasket: Grp A • Manifold: PPF Stainelss 60mm Ext wastegate • Turbo: Garrett GT35bb • Fuelrail: Custom dual 10mm inlet/dual 3bars Fuelregulators • Fuelpumps: 2xWalbo 255L intank • Dump valve: Tial • Turbo damper: Baily • Ignition Leads: Red Magnacor 8.5mm • Engine hoses: Roose Motorsport Hoses "black" • Intercooler: Forge Rs500 • Radiator: Aftermarket Aluminium • Ignition: Msd blaster coil ,Msd 6Al • Air Filter: K&N • Tanks: Bailey Swirlpot, Bailey Header tank, Bailey Breather tank • Engine mounts: Vibratec left+right • Exhaust: Homemade full 3" 1 damper • Enlarged oil pan with Oil baffel • 19row Oilcooler • Oil filter re placing system • Engine management: Converted to Magneti Marelli from S cossie 4x4 • Gearbox: Fixit • Short shift Lenghten shifter • Front diff: 20mm Aluminium Lid by Magnaten • Clutch: Sachs Preasure plate 4paddle sinter lamel Chassi: • Suspension: Gaz Coilovers with help springs • Front Strutbracer: Sparco • Rear Strutbracers: Omp • Busshes: Polly all around • TCA: Compbreak adjustable • Track Rod Ends: Compbreak adjustable • Front Comprsion strut: Compbreak Tarmac Kit adjustable Fälgar, däck och bromsar • Wheels: Oz Racing "Rally Racing" 9x19" Centrelock • Tyres: Bridgestone potenza s03 235/35 Brakes: • Front Calipers: Hi spec Mega monster 6piston • Front Discs: Hi spec 380mm/34mm • Front Pads: Ebc redstuff • Front brakelines: Stailess • Rear Caliper: Ap Racing 4piston • Rear Discs: Ap Racing 330mm/28mm • Rear Pads: Ebc redstuff • Rear brakelines: Stailess • Handbreak: Compbreak Vertical Hydraulic with adjustment valve Interiör / Inredning • Wiechers bolt in Rollcage 6p • Carbon A-pillars • Flocked Dashboard, Centre consol • Carbon dash suround • Birba white dial kit • Mpm Dashlogger • 2xSparco Evo L seats • 2xSparco 3" 4p Harness • Gizzmo MS-IBC boost controller • Snap off • Sparco Mocca Stearing wheel • Sparco Carbon pedal set Exteriör / Styling • Color: Ashblack • Carbon Lower lip (front bumper) • Carbon Middle lip (front bumper) • Carbon Hockey sticks (front bumper) • Rs500 Fog grills (front bumper) • Carbon Grill • Carbon WRC wing • Cup mirrors Mappad till 1,9bar ca500hk där tog spridarna slut finns 1200cc spridare om manb vill mappa vidare.. More Pictures and info: http://www.garaget.org/?car=9480 All org delar finns Inrednings detaljer,Hjul,Bromsar,Baklucka med org Vingen med kolfiber wolf läpp, ++ massa org delar extra Pris/utgångsbud: 390000 Plats/närmaste stad: Ljungby, Sverige
S: Ford Escort Cosworth Motorsport -93 *PROJEKT*
Malmstone replied to Malmstone's topic in Ford selges
Kan säljas som rullande chassi inkl papper 55k -
finns kvar!
http://www.fmcn.no/forum/index.php?showtopic=48078
Tack för kommentaren. Den andra Motorn står o väntar på mitt andra projekt. Och till 400hk behöver man inget 200 block imo.
Nu gör jag ett försök till att sälja den grymt fina bilen. Ashblack Ombyggd till L8 styrbox 205 bottendel med kulpenade org stakar Org kolvar med nya ringar Högtrycks oljepump, nya lager/packingar 4 puck lamell Vevhus ventilation på båda sidor blocket. std olje retur från vevvent är pluggad Grupp A toppackning Org topp med nya lyftare Org Plenum med 20mm Distans Rostfritt Grenrör Hpx500 turbo 3" system med race kat Fuelrail i Alu med snabb kopplingar, dubbla inlopp, utlopp i mitten på rail vidare till en "rail" med dubbla regulatorer drivs av dubbla 255L walbro pumpar i tanken (klarar 800 hk+) Magnacor tändkablar Bailey Turbo dämpare Baily "Mirror" Vevhusburk Gaz coilovers med hjälp fjädrar Fjäderbens stag fram Bussningar och B&M short shift monteras på vxl lådan Framvagnen nya bussningar 18x9" Compomotive MO Guldfärgade med 235/40 däck Stålomspunna broms slangar Fronten RS500 galler Kolfiber läpp, hockeysticks och splitter Bakvinge läpp i kolfiber Mörka Blikers fram och på sidorna samt bakljusen Mycket fin org inredning Birba mätartavlor bla bla bla etc etc Står Avställd och Obes men med org chip/spridare monterat så bes är inga problem. 330kit Ingår dvs Chip,Spridare,mapsensor Finns Massor av delar som kan köpas vid sidan av för att bygga en dräpare. Fler bilder finns här: http://www.garaget.org/?car=9480&image=1065022 O här: http://www.fmcs.nu/forum/showthread.php?t=41907 Vid eventuella frågor etc Ring/Pma etc. Nej tack till en massa spam i tråden. Ev byten Kan vara av intresse kom isåfall med vettiga förslag. Pris/utgångsbud: 195000 Plats/närmaste stad: Ljungby
Vit Escort Cosworth Motorsport -93 "909" *Fullbur *Wrc glasfiber framskärmar *Wrc glasfiber front *Wrc Kolfiber bakvinge *ny *Kolfiber ram mätarhus *Kolfiber Dörrsidor fram *oanvända *Kolfiber grill *Fuel cell 40L *ny *Pedalställ med bromsvåg o cylindrar /hyd koppling *Hyd handbroms x2 *1ny *Bilstein Coilovers fram *Ställbara Krängningshämmare Fram *nytt *Ställbara Länkarmar Fram *nytt *Ställbara Styrleder Fram *nytt *2St Sparco Evo L inkl fästen o skenor *2st Sparco 3" 4punkts bälten "Röda" *4st Oz Rally racing 19x9" Magnesium *Hi-spec Mega monster bromskit 380x34mm 6kolvs *Ap Racing Bromskit 330x28 4kolvs (kass belägg) *Forge rs500 Intercooler *Alu Kylare *ny *Sparco Mocka Ratt *Mpm Dashlogger oanvänd inkl 1tryck/2temp givare *Hks Evc IV (Boost controller) *Bailye Expansion kärl *Bailye Swirlpot *Svarta Roose motorsport slangar Delarn som inte är nya är väldigt lite använda. *Motor:Botten: 200 bottendel med kulpenade org stakar, Cp Kolvar 91.34 borr,Högtrycks oljepump, Nya lager/packingar, Sachs koppling, Vevhus ventilation på båda sidor blocket. Topp: Portad, Mira fräst, Dubbla ventilfjädrar, Bd16+ insugskam, Bd15 avgaskam, Piper cams ställbara drev, PPF grenrör, Gt35bb 1.06 avg, Tial 38mm wastegate, Cobramannen Plenum 3" spjäll, Nuke Fuelrail, Tial Dump, 780cc spridare, Kn Luftfilter, Arp Topp Bultar Lättad i dörrar, bagagelucka, skrapad invändigt Att göra: Svetsa fäste Till Hyd handbroms fixa till torpedväggen för Pedalstället sen lacka invändigt tajma in front fixa montering av bakvinge sen lacka utvändigt. Häng ditt alla delar montera ett soppa system/Broms ledningar köp en fixit eller värre + lite småsaker sen har ni en GRYM BIL De flesta Orginal delar finns till: Diffar,Lysen,Kabelhärva,Motorstyrning, 3" downpipe etc Div Bilder: http://www.garaget.org/?car=102700 Frågor tas via Pm/Telefon Vad som ska ingå kan diskuteras kan säljas som rullande chassie också etc Ta kontakt för mer info. Pris/utgångsbud: 235000 Plats/närmaste stad: Ljungby
Oanvända så inte upkapade för handtag etc ännu. Skulle behöva slängas på ett nytt lager klarlack. Kan även bytas mot 2x Walbro/044 pumpar+filter, Rattnav till esc Cossie, Coilovers bakre till esc cossie+pengar eller så. Pris/utgångsbud: 4000 Plats/närmaste stad: Ljungby
När är den tillverkad (år)?
Hej! Det stämmer det är bara muttrar o ej hubs till. Skulle va möjligt att sälja 4st Ge mig bud på 4.
Ingen intresserad?
8st fälgar 4st muttrar Et 37 55mm Centrumhål 35000 Inkl frakt i Sverige Eller Bud Tel:0046706677112 Jag kan skicka till Närmaste bussgods station i Sverige annars får köparen ordna frakt.
Kan låsas jag bygger klart den..
Till salu igen pga snackare! Et 37 55mm Centrumhål Först med att sätta in pengar på mitt Konto får köpa. Tel:0046706677112 Pris/utgångsbud: 15000+Frakt Plats/närmaste stad: Ljungby/Sverige
1 Hi spec Mega Monster broms kit 380x34mm skivor 6kolvs ok EBC redstuff belägg "Fram" till Cosworth 4x4 brukt på landsvägs körning ca 1500km nypris 26000sek (Kan gå med 18" annars krav 19") 1 Ap racing kit 4kolvs ok och 330x28mm Skivor 4kolvs ok inga belägg Vart monsterat fram på en Subaru impreza men inga problem att tillverka bells/brackets nypris 25000sek Pris för Båda kiten 30000sek Pma/Ring Vid intresse. Tel 0046706677112
nytt pris
Fälgar:Guldfärgade Mo 9x18" Däck: Linglong 235x40 Et 14 Sitter som en Fläskläpp på en Escort Fälgar o däck Körda 4km Nya centrum kåpor finns med ej på bild Pris/utgångsbud: 16000 eller bra bud Plats/närmaste stad: Ljungby/Sverige
S: Oz Racing "mod Rally Racing" 9x19 centrumbult
Malmstone replied to Malmstone's topic in Deler selges
Sålda -
Hela o raka men använda Et 37 Inga hubbar inga däck. Inget tjaffs i tråden Intresserade ringer eller Pmar. Tel:0046706677112 Pris/utgångsbud: 14000 Plats/närmaste stad: Ljungby/Sverige
Escort Cosworth Motorsport -93 "909" *Fullbur *Wrc glasfiber framskärmar *Wrc glasfiber front *Fuel cell 40L *Pedalställ med bromsvåg o cylindrar /hyd koppling *Hyd handbroms *Bilstein Coilovers fram Lättad i dörrar, bagagelucka, skrapad invändigt Orginal delar finns till. Pris: 67000sek eller 80000sek inklusive 18x9" Compomotive fälgar
Dags att skaffa ett nytt projekt att förfina Info om denna bilen då. Motor: 200 bottendel med kulpenade org stakar,Cp Kolvar ala Tg racing,Högtrycks oljepump, nya lager/packingar, 3skivig stål toppackning, Sachs "värsting" 1 lamells koppling, Vevhus ventilation på båda sidor blocket. std olje retur från vevvent är pluggad. Topp: Lagom Portad/ny renoverad topp, Std kammar,ArP Bultar, Piper Kamdrev, Org Plenum med 20mm Distans, Rostfritt Grenrör Med en Hpx500,Fuelrail i Alu med snabb kopplingar, dubbla inlopp, utlopp i mitten på rail vidare till en "rail" med dubbla regulatorer drivs av dubbla 255L walbro pumpar i tanken. Övrigt Motor: Roose Motorsport Slangar "svarta" magnacor tändkablar, Bailey Turbo dämpare, Tial Dumpventil, Forge Intercoler. Chassi: Gaz coilovers med hjälp fjädrar, Fjäderbens stag fram+ bak, Bussningar och B&M short shift monteras på vxl lådan, framvagnen fick även den nya bussningar, framdiffen fick ett förstärkt difflock, Alu behållare i motorummet samt en HKS EVC IV för laddtrycks styrningen. Fälgar, däck och bromsar: 19" Svart lackade OZ superleggera, HI-Spec Mega Monster broms ok, Feroddo Red stuff belägg, 380mm broms skivor, stålomspunna broms slangar, 235*35 däck, Interiör / Inredning: 2 st Sparco Evo L fick installeras tillsammans med varsit Sparco 3" Bälte, liten svart mocka ratt från Sparco, Snap off, Greddy laddtrycks mätare, G-tech Pro, Vita Birba mätartavlor, HKs boost controllern, kolfiber ram runt mätarhuset,samt runt greddy mätaren. Exteriör / Styling: Fronten utsmyckades med RS500 galler, Kolfiber läpp, hockeysticks och splitter, kolfiber grill monterades och även Bakvingeläpp i Kolifiber, Mörka Blikers fram och på sidorna samt bakljusen Helt Ny inte monterad kolfiber huv finns också (15000) bilder/info: http://www.garaget.org/?car=9480 Pris 280000 Sek
Har ett helt nytt Mongoose 3" rostfritt till Esc cossie liggandes. fortfarande inpackat. 6000sek + frakt 0046706677112
