capri-rs Posted January 24, 2007 Posted January 24, 2007 som topic sier.må være til 4x4 "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
Mark1 Posted January 24, 2007 Posted January 24, 2007 Har muligens bd16/16+ send pm om det er interresant.. Hva er forskjell på 4x4 og 2wd kammene? WWW.NorskEscortRegister.Net Escort Mk1/Mk2 register
capri-rs Posted January 24, 2007 Author Posted January 24, 2007 hvis du skal bruke 2wd kammer på 4x4 må det brukes en liten skive bak kamdrevet (eller var det omvendt????) bd 16/16+ er litt hardt uten ventilutfresinger i stempla "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
