Guest Erger Posted December 18, 2007 Posted December 18, 2007 (edited) noen som kanj hjelpe meg med et problem?? mondeo 4x4 som får fuske slag annenhvær km? lurer på å kjøpe å det er opplysninger fra eier.... trenger hjelp fort hvordan er 4hjuls trekket på 96 modellen? er d viskokobling?? Edited December 18, 2007 by Erger
Futte Posted December 19, 2007 Posted December 19, 2007 Hvordan "fuske slag" er det du snakker om?Er det motor som fusker, antispinn, ABS ???? fra http://www.bbc.co.uk/dna/h2g2/A611001 Four-Wheel-Drive Ford Mondeo - Press Release The four-wheel-drive system of the Mondeo 4x4 is similar to that seen in the recently launched Escort 4x4but does not incorporate a viscous couple between the front and rear axles. In order to route the drive to the rear differential, a completely new transfer box has been designed for usein the four-wheel-drive Mondeo - distributing the torque at a ratio of 58 per cent/42 per cent to the front and rear wheels respectively.As in the Escort, torque distribution takes place in the planetary gearset, which has a dual carrier, to ensure the same direction of rotation for front and rear axles. The rear axle layout incorporates the 'Quadralink' arrangement of front-wheel-drive Mondeo models but employs a new rear axle cross member.All Mondeo 4x4 versions are equipped with anti-lock brakes (ASB) and traction control (TCS).TCS is used in place of a viscous couple and controls the speed of each wheel by precise use of the car's braking system under certain driving conditions _______________________ Med hilsen / Best Regards Anders T. Flat Out Racing "When in doubt, go flat out."
Guest Erger Posted December 19, 2007 Posted December 19, 2007 Hvordan "fuske slag" er det du snakker om?Er det motor som fusker, antispinn, ABS ???? fra http://www.bbc.co.uk/dna/h2g2/A611001 Four-Wheel-Drive Ford Mondeo - Press Release The four-wheel-drive system of the Mondeo 4x4 is similar to that seen in the recently launched Escort 4x4but does not incorporate a viscous couple between the front and rear axles. In order to route the drive to the rear differential, a completely new transfer box has been designed for usein the four-wheel-drive Mondeo - distributing the torque at a ratio of 58 per cent/42 per cent to the front and rear wheels respectively.As in the Escort, torque distribution takes place in the planetary gearset, which has a dual carrier, to ensure the same direction of rotation for front and rear axles. The rear axle layout incorporates the 'Quadralink' arrangement of front-wheel-drive Mondeo models but employs a new rear axle cross member.All Mondeo 4x4 versions are equipped with anti-lock brakes (ASB) and traction control (TCS).TCS is used in place of a viscous couple and controls the speed of each wheel by precise use of the car's braking system under certain driving conditions motor fusk jA
WingDude Posted December 19, 2007 Posted December 19, 2007 motor fusk jA Du må være "drømmekunden" for et verksted med en slik beskivelse av symptomer
96mondeo4x4 Posted December 19, 2007 Posted December 19, 2007 Nykking er desverre ikke noen nyhet, når det gjelder mondeo.......Det som ikke er nytt..finner du i arkivet.... let/SØK, og du vil finne.... Gode biler, og mondeo med 4x4 er kjedelig god vinterbil.......Abs enhet er enten dyrt, eller vanskelig å få tak i...en ansatt i ford harstad, eller et anna sted nord for sinsen, ville by relativt mange tusen for en 4x4 delebil jeg hadde til overs, pga abs'en hans hadde ryki. Selv opplevde jeg at drivaksel var "midlertidig" utgått i 2001, da bilen ikke var så veldig gammel............ 1996 Ford Mondeo 2.0 4x4 Kombi Og noe anna fordmorro, 2000 Audi A4 TQ Avant 2000 Audi A3 1.8T 2004 Audi A3 Latskap (samboerens) 2008 Renault Traffic arbeisbil
Futte Posted December 28, 2007 Posted December 28, 2007 (edited) Motorfusk kan være tennplugger, pluggledninger, MAF-sensor o.l.Om det er lenge siden plugger og ledninger er byttet, er det en grei plass å starte.Pluggene bør byttes ved jevne mellomrom. Ellers, kan du kjøpe elektrorens eller lignende som du kan rengjøre MAF-sensor med.Er 2små tråder inni røret rett etter luftfilterboksen. Ikke fall for fristelsen å puss av de med noe du har i hånden, da de lett ryker. Er også en del tips om du bruker SØK -funksjonen på forumet. Edited December 28, 2007 by Futte _______________________ Med hilsen / Best Regards Anders T. Flat Out Racing "When in doubt, go flat out."
