Nilssen Posted June 30, 2008 Share Posted June 30, 2008 Det skal vel ikke være slarke Inn/ut på veiva? Dette er kun når veiva er montert, ikke med råder og stempler.er snakk om 0,5 - 1 mm. Må vell bytte T-Washers som det så fint heter.? Failure is only the opportunity to more intelligently begin again. Henry Ford Link to comment Share on other sites More sharing options...
D.Toft Posted June 30, 2008 Share Posted June 30, 2008 tror du skal bytte dem ja... Link to comment Share on other sites More sharing options...
Nilssen Posted June 30, 2008 Author Share Posted June 30, 2008 Da ble det bytte/Nye. Failure is only the opportunity to more intelligently begin again. Henry Ford Link to comment Share on other sites More sharing options...
