Extreme Posted May 19, 2010 Posted May 19, 2010 (edited) Portat avgashus,bra skick och polerad med intern wg.Passar org grenrör 4x4 och och rwd,dock får man korta downpipe nån cm till nåt av grenrören kommer inte ihåg vilket.Bromsad till 470hk på 1.6bar med cossie spis dock lite högre komp än org i den,mycket mindre motryck med detta avgashus.Jag har 2 bar innan 4000rpm.Nypris 16000:-sv krFinns i Sverige nära Matorp ParkPRIS:8000:- sv kr +46736766164 Edited May 21, 2010 by Extreme www.cosworthclubsweden.se
Extreme Posted May 21, 2010 Author Posted May 21, 2010 (edited) Lägg bud om de är för dyrt. Edited May 21, 2010 by Extreme www.cosworthclubsweden.se
Extreme Posted May 23, 2010 Author Posted May 23, 2010 Mycket fin race turbo som passar rakt på cossie.Lägg bud o saker i inbyte//Fredrik www.cosworthclubsweden.se
capri-rs Posted May 27, 2010 Posted May 27, 2010 hva kan interresant å bytte i da? "Understeer" is when you hit the fence with the front of the car."Oversteer" is when you hit the fence with the rear of the car."Horsepower" is how fast you hit the fence."Torque" is how far you take the fence with you.
Extreme Posted May 27, 2010 Author Posted May 27, 2010 hva kan interresant å bytte i da?Vettiga escort cosworth saker bla.Helst Pengar är klart. www.cosworthclubsweden.se
Extreme Posted May 30, 2010 Author Posted May 30, 2010 Ingen som vill ha en bra turbo o bara skruva på? www.cosworthclubsweden.se
Extreme Posted June 8, 2010 Author Posted June 8, 2010 uppf för denna fina turbo. www.cosworthclubsweden.se
