Ro0ck Posted October 15, 2011 Posted October 15, 2011 Jeg har tatt en diagnose på Mondeo'n idag, men jeg er veldig dårlig på å lese koder, så derfor lurer jeg på om noen her kunne hjulpet meg litt? Det eneste som er gjort med motorn er chip og et KN filter Mondeo MK3 2003 TDCI 2.0 138HK (slightly modified)
Ro0ck Posted October 15, 2011 Author Posted October 15, 2011 P0105: Manifold Absolute Pressure/Barometric Pressure CircuitP0100: Mass or Volume Air Flow CircuitP0235: Turbo/Super Charger Boost Sensor "A" CircuitP0404: Exhaust Gas Recirculation Control Circuit Range/PerformanceP0700: Transmission Control System (MIL Request)P0403: Exhaust Gas Recirculation Control CircuitP0650: Malfunction Indicator Lamp (ML) Control CircuitP0243: Turbo/Super Charger Wastegate Solenoid "A"P0405: Exhaust Gas Recirculation Sensor "A" Circuit LowP0406: Exhaust Gas Recirculation Sensor "A" Circuit HighP0500: Vehicle Speed SensorP0401: Exhaust Gas Recirculation Flow Insufficient DetectedP0402: Exhaust Gas Recirculation Flow Excessive DetectedP2263: Turbo/Super Charger Boost System PerformanceP0560: System VoltageP0325: Knock Sensor 1 Circuit (Bank 1 or Single Sensor)P0200: Injector CircuitP0201: Injector Circuit - Cylinder 1P0203: Injector Circuit - Cylinder 3P0204: Injector Circuit - Cylinder 4P0202: Injector Circuit - Cylinder 2P0251: Injection Pump Fuel Metering Control "A" (Cam/rotor/Injector)P2336: Cylinder #1 Above Knock ThresholdP2338: Cylinder #3 Above Knock ThresholdP2339: Cylinder #4 Above Knock ThresholdP2337: Cylinder #2 Above Knock ThresholdP0603: Internal Control Module Keep Alive Memory (KAM) Error Mondeo MK3 2003 TDCI 2.0 138HK (slightly modified)
grcossie Posted October 15, 2011 Posted October 15, 2011 Ligger en haug med ugyldige koder her virker det som, har du hatt tenninga på med ledningsnett frakoplet her og der? Slett alle kjør en tur og les av på nytt og se hvilken som kommer.
Ro0ck Posted October 15, 2011 Author Posted October 15, 2011 Det som også er et lite problem er at jeg vil ikke kjøre pga en uvanlig vibrasjon i hele bilen, og glødelampa blinker hele tiden! Mondeo MK3 2003 TDCI 2.0 138HK (slightly modified)
grcossie Posted October 15, 2011 Posted October 15, 2011 Slett feilkodene og se om glødelampa blinker forsatt, ved oppstart
Ro0ck Posted October 15, 2011 Author Posted October 15, 2011 Jeg regner med at det er dysene som fucker opp mye her.... Mondeo MK3 2003 TDCI 2.0 138HK (slightly modified)
Etern1ty Posted October 15, 2011 Posted October 15, 2011 ser ut som om spenning forårsaker ett par av disse? unormalt høy/lav? bankesensor gir 5 av feilkodene, kan være relatert til spenninga 1990 Ford Sierra 2.0 OHC bruksbil1974 Ford Mustang Fastback D1 V8 (kompressorprosjekt)1974 Ford Mustang Mach 1 (delebil)1984 Ford Granada 2.3L Jubileum (vraket) Delesalg1969 Ford Taunus 12M (solgt)1993 Ford Escort RS2000 (solgt)
grcossie Posted October 15, 2011 Posted October 15, 2011 Dysene kan nok være et problem, men det er ikke normalt med så mangen feilkoder bare pga de. Er svært skjelden vi ser så mangen feilkoder, uten at det har vært lite strøm, eller fra koplet ledningsnett
Ro0ck Posted October 15, 2011 Author Posted October 15, 2011 ser ut som om spenning forårsaker ett par av disse? unormalt høy/lav? bankesensor gir 5 av feilkodene, kan være relatert til spenninga Kan det være at jeg har hatt annlegget koblet til batteriet? Mondeo MK3 2003 TDCI 2.0 138HK (slightly modified)
