and Posted June 6, 2005 Posted June 6, 2005 Ford plans hottest hatch of all Ford is rumoured to be considering a 350bhp, four-wheel-drive, six-cylinder turbocharged proposal for the next-generation Focus RS. Right now the Blue Oval’s executives at the company’s headquarters in Cologne, Germany are considering a plan to fit Ford’s new flagship hot hatch, due out in 2007, with a new turbocharged in-line six-cylinder engine. The advanced powerplant (right) has been developed by Volvo as a replacement for the Swedish car maker’s current six-cylinder engine, and is planned to make its debut in the new S80 due out next June. Conceived for both transverse and longitudinal applications, the four-valve-per-cylinder unit is based around a die-cast aluminium cylinder block for an all-up weight of 180kg. It is also claimed to be 1mm shorter than Volvo’s five-cylinder engine – a feature that makes it suitable for a whole range of different models, including the new Focus RS. Three different versions of the engine are planned: a base naturally aspirated 3.2-litre and a pair of performance-oriented turbocharged 3.0-litre units. The former receives variable cam timing (VCT) on the inlet valves, with the latter two adopting a system operating both the inlet and exhaust valves as well as a variable-vane Garrett turbocharger. In 3.2-litre guise, the new six-cylinder produces 235bhp at 6000rpm along with 236lb ft of torque at 3500rpm – an increase of 38bhp and 26lb ft over Volvo’s current 2.9-litre engine. The turbocharged units deliver 285bhp and 295lb ft in light-pressure guise, with the high-pressure unit pumping out a BMW M3-beating 350bhp and 332lb ft. It’s this latter specification that Ford’s Motorsport boss, Jost Capito, may use to thrust the Blue Oval back to the very top of the European hot-hatch ranks. If Ford’s plans come to fruition, the new RS will boast a whopping 133bhp and 96lb ft more than the upcoming Focus ST, whose turbocharged 2.5-litre five-cylinder engine generates 217bhp along with 236lb ft of torque. Unlike the front-wheel-drive ST, the new RS is being developed around new four-wheel-drive underpinnings. This promises to endow it with spectacular levels of grip and traction. One problem, however, is the lack of a suitable six-speed manual transmission for the new car. The gearbox in the Mondeo ST TDCi is rated to 295lb ft, although insiders say measures are being taken to upgrade it for use in performance-oriented Volvos. Kilde http://www.autocarmag.com 350bhp og 332lb ft. som tilsvarer 450Nm i en Focus er ville siffere. Også en R6er! Denne blir ikke god når avgiftnorge krever sitt bidrag.. 1 lb-ft = 1.356 Nm for omregning av moment. FCN og VCCN Sessongåpner Gardermoen søndag 4 mai 2025 Sessongåpner-gardermoen-4-mai-2025 FCN Vålerbanen 6-7 juni 2025 (Del1) FCN Hovedtreff Vålerbanen 6-7-juni 2025 (Del1). FCN Vålerbanen 22-23 august 2025 (Del2) FCN på GMS 5-7 september 2025 Grenland Motorsportsenter helgen 5-7 september 2025 FCN Sessongavslutter Gardermoen søndag 28 september 2025 Sessongavslutter-gardermoen-28-september-2025
Guest RSabuser Posted June 8, 2005 Posted June 8, 2005 en annen side Står flere steder, får håpe det er noe i ryktene da.
Guest theend Posted June 8, 2005 Posted June 8, 2005 Hørte dem skulle bruke 5-sylindra jeg...?Samme motoren som er i T5'ene... Men, leste det i autofil eller vi menn bil eller no slikt..Opplever ofte at deres "fakta" ikke stemmer...
Guest RSabuser Posted June 8, 2005 Posted June 8, 2005 Hørte dem skulle bruke 5-sylindra jeg...?Samme motoren som er i T5'ene... Men, leste det i autofil eller vi menn bil eller no slikt..Opplever ofte at deres "fakta" ikke stemmer...<{POST_SNAPBACK}>st'en skal ha 5'eren
and Posted June 8, 2005 Author Posted June 8, 2005 Står flere steder, får håpe det er noe i ryktene da. Den nye karossen er helt sikkert tegna med 4wd i tankene, men det blir litt offrack med rekke6 synes jeg. Blir litt Golf med stor motor. Ett imponerende stykke kraftig teknologi i seg selv, men uten noen racing/rally/mesterskaphistorie eller kred. Føler nesten at nye Mk2 RS ryktet er tiltenkt USAmarkedet. Er litt voldsom pakke. Eller er det for å teste/lekke markedet for en Hiperformance R6 Volvomotor i kommende Volvo Rserier.. FCN og VCCN Sessongåpner Gardermoen søndag 4 mai 2025 Sessongåpner-gardermoen-4-mai-2025 FCN Vålerbanen 6-7 juni 2025 (Del1) FCN Hovedtreff Vålerbanen 6-7-juni 2025 (Del1). FCN Vålerbanen 22-23 august 2025 (Del2) FCN på GMS 5-7 september 2025 Grenland Motorsportsenter helgen 5-7 september 2025 FCN Sessongavslutter Gardermoen søndag 28 september 2025 Sessongavslutter-gardermoen-28-september-2025
Guest theend Posted September 1, 2005 Posted September 1, 2005 Skumma gjennom autofil i dag, mener å huske noe om at planene om focus rs er kansellert, pga økonomien... :( satser på at dette er bare bull derifra...
Guest jaredboy Posted September 1, 2005 Posted September 1, 2005 Leste akkurat det samme i evo her om dagen..ikke morro..De skrev at ford kun skulle satse på ST modelene, og legge RS på is..for nå
