  • and changed the title to SEMA 2026 eller Capri Mk1 My Generationtråden
Stoler fra https://scheel-mann.de
https://www.instagram.com/scheelmannusa/p/DfYYJDYm0PO/
Felger fra https://www.americanracing.com/american-racing-vintage-vn477
Lages på bestilling i 14" til 17" om noen vil ha på egen bil.
https://www.instagram.com/americanracing/p/DffC_1fm9gu/
En kikk under: https://www.instagram.com/jh_restorations/reel/DfU6riMC4Cm/
Spekkliste:
Engine
-347 Ford Racing V8
-Borla Induction 8 Stack fuel injection intake
-Holley Terminator X fuel induction tuned by @dr__efi
-Vibrant custom Stainless Steel exhaust with 3D printed Ultimate Headers Z crossover pipe and Deeds exhaust mounts and tips
-Dewitts Radiator with Spal Brushless Cooling Electric fans
-Holley Mid Mount Accessory Drive kit
-360hp and 400ft/lb of torque
-Custom fabricated 16 gallons in-trunk fuel tank
Drive Train
-Tremec TKX 5 speed transmission
-DriveShaft Shop custom drive shaft
-Summit Racing Clutch
-Detroit Speed FN988 8.8in center section in a Moser 9in housing / 3.55gears
-Wilwood 6 piston XRS 13 inch front brakes and 4 piston XRS 13 rear disc brakes
-Electric brake booster with Wilwood master
Suspension
-3D scanned and custom engineered front and rear suspension
-Front custom lower control arms and Gaz Racing coilovers with custom designed billet front hubs
-Rear triangulated 4 link with Ridetech R-Joints and custom valved Gaz Racing coilovers
-17x9 front and 17x9.5 rear American Racing VN477 Wheels
-Toyo Proxy Sport R Tires, 235/40ZR17 Front, and 255/40ZR17 Rear
Kan Capri Mk1 bli den nye 240Z? Det er hva denne Capri gir meg følelsen av.
Og når vi først er på japsesporet. Her er feite felger fra Japan.
