and Posted 1 hour ago Posted 1 hour ago Noen husker kanskje en Merkur fra 2023? I år er de tilbake med en Capri Mk1 1974. Breddingen er ute til diskusjon, men interiøret er rockestjerna her. Bilder, tekst og video fra interiørbyggere her: https://dclass.co.uk/project--my-generation FCN Grenland Motorsportsenter 30 juli - 1 august 2027
and Posted 1 hour ago Author Posted 1 hour ago Stoler fra https://scheel-mann.de https://www.instagram.com/scheelmannusa/p/DfYYJDYm0PO/ Felger fra https://www.americanracing.com/american-racing-vintage-vn477 Lages på bestilling i 14" til 17" om noen vil ha på egen bil. https://www.instagram.com/americanracing/p/DffC_1fm9gu/ En kikk under: https://www.instagram.com/jh_restorations/reel/DfU6riMC4Cm/ Spekkliste: Engine -347 Ford Racing V8 -Borla Induction 8 Stack fuel injection intake -Holley Terminator X fuel induction tuned by @dr__efi -Vibrant custom Stainless Steel exhaust with 3D printed Ultimate Headers Z crossover pipe and Deeds exhaust mounts and tips -Dewitts Radiator with Spal Brushless Cooling Electric fans -Holley Mid Mount Accessory Drive kit -360hp and 400ft/lb of torque -Custom fabricated 16 gallons in-trunk fuel tank Drive Train -Tremec TKX 5 speed transmission -DriveShaft Shop custom drive shaft -Summit Racing Clutch -Detroit Speed FN988 8.8in center section in a Moser 9in housing / 3.55gears -Wilwood 6 piston XRS 13 inch front brakes and 4 piston XRS 13 rear disc brakes -Electric brake booster with Wilwood master Suspension -3D scanned and custom engineered front and rear suspension -Front custom lower control arms and Gaz Racing coilovers with custom designed billet front hubs -Rear triangulated 4 link with Ridetech R-Joints and custom valved Gaz Racing coilovers -17x9 front and 17x9.5 rear American Racing VN477 Wheels -Toyo Proxy Sport R Tires, 235/40ZR17 Front, and 255/40ZR17 Rear FCN Grenland Motorsportsenter 30 juli - 1 august 2027
and Posted 1 hour ago Author Posted 1 hour ago Lykter fra https://www.dapperlighting.com FCN Grenland Motorsportsenter 30 juli - 1 august 2027
and Posted 51 minutes ago Author Posted 51 minutes ago Kan Capri Mk1 bli den nye 240Z? Det er hva denne Capri gir meg følelsen av. Og når vi først er på japsesporet. Her er feite felger fra Japan. FCN Grenland Motorsportsenter 30 juli - 1 august 2027
