Ronny Posted July 28, 2005 Share Posted July 28, 2005 Er disse samme som på scorpio?? Handbremsen er treig på retur.....-Åpne og gjøre reint, eller bytte ut?? 287Hk/440Nm på hjulene@1,85bar. Sierra is-Turbo, Garrett T4, Audi S2 WG, Rs500Cooler, Autronic, Spec Stage5 Drag-clutch(716Nm), Siemens Deka 3105 (840cc). Kommer: FullPreppa Topp m/kvassere kam, Rustfritt Grenrør, rustfritt 3" Magnex. 60mm Wastegate.+++ Link to comment Share on other sites More sharing options...
Ronny Posted July 29, 2005 Author Share Posted July 29, 2005 Er det ingen som veit??? 287Hk/440Nm på hjulene@1,85bar. Sierra is-Turbo, Garrett T4, Audi S2 WG, Rs500Cooler, Autronic, Spec Stage5 Drag-clutch(716Nm), Siemens Deka 3105 (840cc). Kommer: FullPreppa Topp m/kvassere kam, Rustfritt Grenrør, rustfritt 3" Magnex. 60mm Wastegate.+++ Link to comment Share on other sites More sharing options...
bige Posted July 30, 2005 Share Posted July 30, 2005 http://www.budweg.com/budwegweb/en/http://www.mekonomen.no/katalog.asp?butik=6008-000&sprak=NDet er lov og leite selv ........ Link to comment Share on other sites More sharing options...
Ronny Posted July 30, 2005 Author Share Posted July 30, 2005 Takker!! Fantastisk verktøy! 287Hk/440Nm på hjulene@1,85bar. Sierra is-Turbo, Garrett T4, Audi S2 WG, Rs500Cooler, Autronic, Spec Stage5 Drag-clutch(716Nm), Siemens Deka 3105 (840cc). Kommer: FullPreppa Topp m/kvassere kam, Rustfritt Grenrør, rustfritt 3" Magnex. 60mm Wastegate.+++ Link to comment Share on other sites More sharing options...
Guest viko Posted August 2, 2005 Share Posted August 2, 2005 Takker!! Fantastisk verktøy! <{POST_SNAPBACK}> scorpio og cosworth 4x4 har like calipper bak med 20mm discog 2wd cosworth likt som sierra 2.8 Link to comment Share on other sites More sharing options...
Ronny Posted August 2, 2005 Author Share Posted August 2, 2005 Takker!! Fantastisk verktøy! <{POST_SNAPBACK}> scorpio og cosworth 4x4 har like calipper bak med 20mm discog 2wd cosworth likt som sierra 2.8<{POST_SNAPBACK}> Jeg forstod det slik i katalogen hos mekonomen at cosworth 2wd, scorpio, sierra med abs og sierra 2,8/2,9 har like calippere. Og trodde at cosse 4wd bruker annen calipper pga ventilerte/tykkere skiver bak! Blir ikke det riktig da tro?? 287Hk/440Nm på hjulene@1,85bar. Sierra is-Turbo, Garrett T4, Audi S2 WG, Rs500Cooler, Autronic, Spec Stage5 Drag-clutch(716Nm), Siemens Deka 3105 (840cc). Kommer: FullPreppa Topp m/kvassere kam, Rustfritt Grenrør, rustfritt 3" Magnex. 60mm Wastegate.+++ Link to comment Share on other sites More sharing options...
Jonny.B Posted August 2, 2005 Share Posted August 2, 2005 Takker!! Fantastisk verktøy! <{POST_SNAPBACK}> scorpio og cosworth 4x4 har like calipper bak med 20mm discog 2wd cosworth likt som sierra 2.8<{POST_SNAPBACK}> Jeg forstod det slik i katalogen hos mekonomen at cosworth 2wd, scorpio, sierra med abs og sierra 2,8/2,9 har like calippere. Og trodde at cosse 4wd bruker annen calipper pga ventilerte/tykkere skiver bak! Blir ikke det riktig da tro?? <{POST_SNAPBACK}> jepp,det er helt riktig det ronny,4x4 caliptere er bredere pga ventilert skive,den calipteren for du ikke kjøpt hos mekonomen,kun orginalt tipper jeg.... Prosjekt Electric orange Cossie Link to comment Share on other sites More sharing options...
