Escort Cosworth Parts Engine Pr unit AIR FILTERS £10.00 AIR FILTER TO TURBO HOSES £40.00 ALTERNATORS NEW £150.00 ALTERNATORS USED £90.00 ALTERNATORS BRACKET STD £45.00 ALTERNATORS BRACKET GRPA £90.00 ALTERNATORS PULLEYS GRPA £75.00 ALTERNATOR STRAP CLAMPS £25.00 CRANK SENSORS £20.00 DISTRIDUTOR USED £50.00 DISTRIBUTOR NEW £100.00 DISTRIBUTOR CAPS USED £10.00 DISTRIBUTOR CAPS NEW £15.00 DISTRIBUTOR ROTOR NEW £5.00 DIP STICK TUBES £10.00 DIP STICK £5.00 ENGINE SANDWICH PLATE £25.00 ENGINE LOOMS £150.00 ENGINE MOUNT BRACKETS ALLOY STD £15.00 ENGINE X MEMBERS NEW £100.00 EXHAUST MANIFOLD GASKET £90.00 EXHAUST RUBBER MOUNT £2.00 EXHAUST BRACKETS £2.00 EXHAUST FRONT PIPE GPN £80.00 EXHAUST CENTRE £50.00 EXHAUST REAR TAIL PIPES £30.00 FAN BELTS £5.00 FUEL FILTER NEW £20.00 FUEL REG NEW STD £75.00 FUEL REG NEW GRPA £125.00 FUEL REG WRC £150.00 FUEL REG NEW SAPH : £75.00 FUEL RAIL NEW GRPN £75.00 FUEL RAIL NEW STD £90.00 FRONT PULLEY STD £75.00 FRONT PULLEY F2 STD £75.00 FRONT PULLY F2 GRPA £175.00 GRPA HEAD NUTS £9.00 GRPA HEAD BOLTS £15.00 SHORT GPA STUDS ARP £10.00 HP BOSCH FUEL PUMPS (SUBMERGED) NEW £150.00 HP FUEL PUMP SENDER ASSY NEW £80.00 HT LEADS SETS £50.00 INLET PLENUMS GPA £100.00 INJECTORS BLUE STD £35.00 ING COILS NEW £20.00 IDLE VALVE GREY £50.00 INTERCOOLER HOSES TO PLEM £25.00 INTERCOOLER HOSES TO TURBO £25.00 K&N AIR FILTERS NEW £25.00 LAMBA SENSORS £150.00 MAP SENSORS 2.5 BAR STD £50.00 MAP SENSORS 3 BAR £95.00 MAP SENSORS BRACKETS £20.00 OIL FILTER REMOTE £15.00 OIL PRESSURE SWITCHERS £15.00 OIL COOLERS £75.00 SET SPARK PLUGS ACP902P £20.00 SET SPARK PLUGS C55TT £20.00 SETS SPARK PLUGS 57C £20.00 SETS SPARK PLUGS 59 C £25.00 STARTER MOTORS USED £55.00 STARTER MOTORS NEW £100.00 THERMOSTAT HOUSING STD £15.00 THERMOSTAT HOUSING GRPA £35.00 THERMOSTAT HOUSING F2 £25.00 THROTTLE BODY NEW £150.00 THROTTLE BODY USED £60.00 THROTTLE BODY EEC 4 £100.00 THROTTLE POTS SWITCH BLACK £60.00 THROTTLE POTS SWITCH RED £60.00 THROTTLE CABLES NEW £20.00 THROTTLE PEDAL £25.00 TFI £45.00 TIMING BELT TENSIONERS NEW £50.00 TURBO DUMP VALVE PLASTIC £15.00 TURBO HEATSHIELD £50.00 TURBO GRPA 247 NEW £1,250.00 TURBO DRAIN PIPES £10.00 TURBO DRAIN RUBBER PIPES £5.00 TURBO WATER PIPES £5.00 TURBO OIL FEED PIPES £20.00 TURBO OVERHAUL KIT £100.00 VALVE SPRING CAPS £10.00 WATER PUMPS NEW RS500 £75.00 WATER PUMPS NEW 4X4 £75.00 WATER TEMP SWITCHERS £8.00 WATER PUMP PULLEYS £25.00     Gearbox A.P. CLUTCH KITS USED (PADDLE) £200.00 AP CLUTCH PLATES USED £50.00 AP CLUTCH COVERS £150.00 CLUTCH FORKS NEW £10.00 CLUTCH FORKS BOOTS £5.00 GEARBOX CRADLE TO BODY BRACKETS £5.00 GEARBOX CRADLES NEW £35.00 GEARLEVERS NEW £35.00 GEAR LEVERS LINKAGE £25.00 GEAR LEVER BOOTS £5.00 GRP N CLUTCH CABLES ADJ £60.00 STD CLUTCH CABLE £10.00 GRP N CLUTCH CABLES SPACERS £12.00 GRP A CLUTCH BEARING £30.00 MODIFED GRP N CLUTCH PEDALS £55.00 REV LIGHT SWITCH £45.00 STD CLUTCH PEDALS £45.00 STANDARD RATIO GPN GEARBOXES £750.00 THRUST BEARINGS £22.00 SPEEDO CABLES £20.00 SPEEDO DRIVES ELEC £35.00 SPEEDO DRIVES MECH £15.00 SPEEDO HOUSINGS £25.00 SPEEDO DRIVE GEAR £20.00   Prop FRONT PROPSHAFT NEW £125 FRONT PROPSHAFT USED £50 REAR PROPSHAFTS NEW £150 REAR PROPSHAFTS USED £100 RUBBER PROPSHAFT COUPLINGS £75   Diffs CROSS SHAFT NEW £90.00 CROSS SHAFT USED £50.00 FRONT DIFF ASSY REBUILT £150.00 GRP N DIFF MOUNTS NEW £75.00 GRP N DIFF MOUNTS USED £50.00 GRPA DIFF MOUNTS NEW £45.00 REAR DIFF ASSY 3.6 REBUILT £350.00 Drive Shafts CV GAITER KITS NEW £15.00 FRONT DRIVESHAFTS NEW £175.00 FRONT DRIVESHAFTS USED £125.00 REAR DRIVE SHAFT DOWELS £4.00 REAR DRIVESHAFTS SHORT NEW £150.00 REAR DRIVESHAFTS LONG NEW £150.00 REAR DRIVESHAFTS USED £100.00 DRIVE SHAFTS BEAR £25.00   Front Suspension SETS STD TCA OUTER BUSH NEW £30.00 FRT ANTI ROLL BARS 28mm £50.00 FRT ANTI ROLL BARS 26mm £50.00 COMP ANTI ROLL CLAMPS 26mm £15.00 COMP ANTI ROLL CLAMPS 28 mm £15.00 ANTI ROLL CLAMPS STD £8.00 COMP 26mm FRT A.R.B. RUBBERS £15.00 COMP 28mm FRT A.R.B. RUBBERS £15.00 FRONT HUB FLANGES NEW £50.00 FRONT HUB FLANGES NEW GPA STUDS £55.00 FRONT UPRIGHT COMPLETE WITH HUBS STD NEW £100.00 FRONT UPRIGHTS NEW BARE £70.00 COMPLETE FRONT UPRIGHTS MODIFIED USED £200.00 FRT UPRIGHT TO TCA SPACERS £15.00 FRT & REAR WHEEL BEARING KITS NEW £40.00 INNER TCA COMP BUSHES £45.00 GRP N TCA NEW £65.00 GRP N TCA USED £35.00 P.A.S. PUMP NEW £125.00 P.A.S. PUMP USED £75.00 PAS STEEL PIPE £35.00 PAS ALLOY PIPE £25.00 PAS HIGH PRESS PIPE £75.00 PAS LOW PRESS PIPE £35.00 P.A.S. BRACKET £25.00 P.A.S. PULLEY STD £25.00 P.A.S. PULLEY ALLOY £45.00 P.A.S. RES NEW £30.00 STEERING SHAFTS LOWER NEW £65.00 STEERING UPPER COLUMES NEW £45.00 STEERING RACKS LHD £450.00 STEERING WHEELS (MOMO , SPARCO) USED £60.00 STEERING WHEEL BOSS LONG £30.00 STEERING RACKS BOOTS £7.00 STD TRACK ROD ENDS NEW £10.00 COMP TRACK ROD ENDS £25.00 TRACK RODS NEW £40.00   Rear Suspension REAR ANTI ROLL BARS 18mm £40.00 REAR ANTI ROLL BARS 20mm £40.00 REAR A.R.B. RUBBERS 18 mm £10.00 REAR A,R,B,RUBBERS 22mm £10.00 REAR A,R,B CLAMPS £4.00 REAR ARM ADJUSTERS ROSE JOINTS £50.00 REAR ARM ADJUSTERS £50.00 REAR HUB CARRIERS NEW £75.00 REAR HUB FLANGES NEW £50.00 REAR HUB FLANGES WITH GRPA STUDS NEW £75.00 REAR STUB SHAFTS NEW £75.00 REAR STUB SHAFTS USED £50.00 STD REAR ARMS NEW £100.00 GPA REAR BEAM PLATES £45.00 STD REAR BEAMS PLATES £30.00 STD REAR BEAMS USED £90.00 REAR BEAMS GRP A ROUND TYPE £350.00   Front Dampers DAMPERS COMPLETE GRAVEL £250.00 DAMPERS COMPLETE RACE £300.00 DAMPERS COMPLETE TARMAC £250.00 DAMPERS COMPLETE £300.00 DAMPERS COMPLETE GRAVEL £300.00   Rear Dampers DAMPERS COMPLETE £200.00 DAMPERS COMPLETE £200.00 DAMPERS COMPLETE RACE £250.00 DAMPERS COMPLETE £200.00 DAMPERS COMPLETE £200.00 GPA 2WD SIERRA F/ DAMPER COMPLETE £250.00 2WD SIERRA DAMPERS COMPLETE £200.00   Springs Front SPRINGS £50.00 70-91-15 RED £50.00 60-60-30 RED £50.00 SPRINGS £50.00 SPRINGS 28NM FRONT £45.00 SPRINGS 30NM FRONT £45.00 SPRINGS 32NM FRONT £45.00 SPRINGS 44NM FRONT £45.00 SPRINGS 57NM FRONT £45.00 SPRINGS 65NM FRONT £45.00 SPRINGS 68NM FRONT £45.00 SPRINGS 68NM FRONT £45.00 SPRINGS 70NM FRONT £45.00 SPRINGS 70NM FRONT £45.00 SPRINGS 72NM FRONT £35.00 SPRINGS 72NM FRONT £35.00 SPRINGS 75NM FRONT £35.00 SPRINGS 30NM FRONT £35.00 SPRINGS 80NM FRONT £35.00 SPRINGS 85NM FRONT £45.00 SPRINGS 85NM FRONT £35.00 SPRINGS 140NM FRONT £45.00 SPRINGS 150NM FRONT £45.00 SPRINGS 90NM FRONT £45.00 SPRINGS 92.5NM FRONT £45.00 SPRINGS 95NM FRONT £45.00 SPRINGS 100NM FRONT £45.00 SPRINGS 55NM FRONT £45.00 SPRINGS 110NM FRONT £45.00 SPRINGS 80NM FRONT £45.00 SPRINGS 85NM FRONT £45.00 SPRINGS 130NM FRONT £45.00 SPRINGS 210NM FRONT £45.00   SPRINGS 275LBS/FT FRONT £35.00 SPRINGS 450LBS/FT FRONT £35.00 9" 650LB FRONT £55.00 300-60-80 EIBACH FRONT £45.00 C515 FRONT £45.00 SPRINGS 48-66-99 FRONT £35.00 SPRINGS 54-73-109 FRONT £35.00 SPRINGS 300LBS FRONT £35.00 SPRINGS 55NM FRONT £35.00 SPRINGS FRONT £35.00 SPRINGS 65NM £35.00 SPRINGS 40NM 50MM £45.00 SPRINGS 44NM 50MM £45.00 SPRINGS 55NM 50MM £45.00 SPRINGS 45NM 50MM £45.00   Springs Rear SPRINGS 22NM REAR £35.00 SPRINGS 26NM REAR £35.00 SPRINGS 28NM REAR £35.00 SPRINGS 32NM REAR £35.00 SPRINGS 38NM REAR £35.00 SPRINGS REAR £35.00 SPRINGS 38NM REAR £35.00 9094093 GRAVEL REAR £35.00 SPRINGS 35NM REAR £35.00 SPRINGS 40NM REAR £35.00 SPRINGS 45NM REAR £35.00 SPRINGS 80NM £35.00 SPRINGS 30-35-45 REAR £35.00 SPRINGS 30NM REAR £35.00 SPRINGS 72NM REAR £35.00 SPRINGS 48NM REAR £35.00 SPRINGS 48NM REAR £35.00 SPRINGS 90NM REAR £35.00 SPRINGS 36NM REAR £35.00 SPRINGS 12"/180 REAR £30.00 9096414 GRAVEL REAR £35.00     Brakes ALLOY HAND BRAKE LEVERS £45.00 BRAKE ACTUATOR ASSY NEW £250.00 BRAKE VALVE NEW £400.00 CARBON FRONT PADS SETS £60.00 CARBON REAR PADS SETS GPN NEW £45.00 FRONT BRAKE CALIPER NEW £100.00 ADJUSTABLE PEDAL BOXES £450.00 STD PEDAL BOXES £150.00 REAR BRAKE CALIPERS NEW £100.00 SET FRONT DISCS NEW £50.00 SET REAR DISCS NEW £50.00 SETS PADGED FRONT PADS GPN £90.00 SET FRONT 355mm PADS £75.00 SET 285mm PADS £45.00 SETS GPA 315mm PADS £55.00   Guards ALLOY REAR DIFF SHIELD NEW £75.00 ALLOY REAR DIFF SHIELD USED £50.00 ALLOY SUMPSHIELD NEW £250.00 ALLOY SUMPSHIELD USED £200.00 KEVLAR TANK GUARD USED £150.00 SUMP SHIELD FRONT BARS NEW £75.00 SUMP SHIELD SIDE BRACKETS NEW £100.00 SUMPSHIELD X MEMBERS NEW £100.00 TURRET BRACE BARS NEW £50.00 TURRET BRACE BRACKETS £50.00 SIDE JACKS £45.00   Electrial HORNS NEW £50.00 LHD WIPER LINKAGE NEW £50.00 WIPER ARMS & BLADES NEW £20.00 WIPER MOTORS £50.00 IND / WIPER SWITCHES NEW £50.00 VDO OIL SENDER £45.00 VDO FUEL SENDER £45.00 VDO FUEL GAUGE £35.00 VDO OIL GAUGE £35.00   Water System TOP HOSES £5.00 BOTTOM HOSES £6.00 HEATER HOSES SMALL £3.00 HEATER HOSES MED £4.00 HEATER HOSES LARGE £5.00 HEADER TANK TO TURBO £5.00 HEATER HOSES LARGE £5.00 HEATER MATRIX £50.00 HEADER TANK NEW £45.00 RAD FANS NEW £100.00 RADIATOR C/W FANS NEW £175.00 RAD FANS USED £35.00 RAD FANS LARGE £50.00 RAD FANS C/W CRADLE NEW £100.00 RAD FANS SWITCHES £35.00 STEEL PIPES ENGINE £15.00 STEEL PIPES RAD £10.00 RAD CAPS £10.00   Body BONNET £100.00 BONNET GRILLS NEW £50.00 BUMPER LOWER GRILLS £50.00 DOOR GLASS R/H NEW £75.00 DOOR GLASS L/H NEW £75.00 DOOR LOCK ASSY £50.00 DOOR MIRRORS NEW £50.00 DOORS £100.00 FUEL TANK CAP £10.00 HEATED REAR SCREENS NEW £50.00 HEATER BOXES NEW £50.00 HEATER MOTORS NEW £50.00 N/S REAR QYT PANEL NEW £350.00 O/S REAR QYT PANEL NEW £350.00 REAR QRT GLASSES R/H NEW £45.00 REAR QRT GLASSES L/H NEW £45.00 SETS BONNET HINGES £10.00 SETS DOOR TRIMS £75.00 SETS MOULDED MUD FLAPS USED/ NEW £90.00 SETS SIDE SKIRTS NEW £150.00 SIDE SILL ENDS £50.00 TAILGATES £50.00   LHD ESCORT COSWORTH GPA BODYSHELL £2,500.00   Lamps FRONT HEADLAMPS R/H NEW £75.00 FRONT HEADLAMPS L/H NEW £75.00 LAMP POD COMPLETE NEW £200.00 LAMP POD ONLY £60.00   Wheels 5.5X13 SPOKED WHEELS £90.00 7X15 OZ WHEELS £55.00 5X16 OZ ICE WHEELS USED £65.00 6X16 OZ SNOW WHEELS USED £65.00 6X16 OZ WHEELS NEW £75.00 7X15 MAG CROMODORA F2 £75.00 7X16 SPEEDLINE GPA £65.00 8X16 SIERRA GPA MAG £75.00 6X15 COMPOMOTIVE GPA £55.00 WORKSHOP TOOLS 130 AMP MIG WELDER £50.00 TYRE CUTTER £150.00 TYRE TEMP PROBE £100.00         Focus Parts K&N AIR FILTERS £37.20 EXHAUST DOWNPIPE £240.50 MAP SENSOR BRACKET £10.62 WATER HOSE TOP £6.66 WATER HOSE MODEM £7.42 TURBO 90deg PLENUM ELBOW £32.14 ALLOY BREATHER TANKS £188.50 TURBO HOSE 90deg ELBOW £43.94 100mm ALLOY TURBO JOINERS £16.50 TURBO COMP/HOUSEING HOSE £31.84 THROTTLE HOUSEING ADAPTOR £55.38 TURBO WATER PIPE £11.78 ALLOY JOINER £11.50 TURBO TO INTERCOOLER ALLOY PIPE £62.50 T/HOUSING BRACKET INSULATOR £1.45 45deg TURBO TO AIR FILTER HOSE £42.82 TURBO/AIR FILTER REDUCER £24.81 BATTERY TRAY MOUNTING BOBINS £7.50 MODIFIED BATTERY TRAYS £80.25 FOCUS RALLY SUMP GUARD SUPPORT BRACKET £75.23 FOCUS RALLY SUMP GUARD SUPPORT BAR £150.00 EXHAUST REAR BOX £85.50 SET GEAR CHANGE CABLES £95.20 T190 /250 BONNET VENTS £34.60 MODIFIED FUEL PUMP £145.50 AIR BAG KIT £750.90 T250 QUAIFE SEQUENTIAL GEAR LEVER £450.00 PAIR STD FRONT UPRIGHTS COMPLETE WITH BRAKES £200.00 PAIR SIDE SILLS £45.20 STD GEAR LEVER £37.80 T250 ( FOCUS RS )FRONT BUMPER NEW £200.00   GPA PARTS 355 X 28 MM FRONT DISCS NEW £200.00 355 X 28 MM FRONT BREMBO DISCS USED £150.00 355 X 28MM FRONT AP DISCS USED £150.00 310 X 28 MM FRONT AP DISCS USED £80.00 ALLOY AP RADIAL MOUNT BRACKETS £25.00 TRACK ROD ENDS £10.00 STEERING RACK YOKES £25.00 TRACK ROD ENDS ROSE JOINTS £35.00 ALLOY WHEEL NUTS £5.00 GPA ESCORT WHEEL STUDS £5.00 7 SPEED FF CLUTCH FORK AND BEARING £100.00 7 SPEED FF DOG RINGS £60.00 7 SPEED FF GEARS £70.00 ALTENATOR HEAT SHIELDS £25.00     GPA ESCORT PARTS Engine PRICE AIR FILTER BOXERS £50.00 ALTERNATORS USED £150.00 ALTERNATORS BRACKET GRPA £60.00 ALTERNATORS PULLEYS GRPA £60.00 ENGINE MOUNTS STD £10.00 ENGINE X MEMBERS £35.00 EXHAUST FRONT PIPE £55.00 EXHAUST CENTRE £45.00 EXHAUST REAR TAIL PIPES £55.00 OIL FILTER REMOTE £150.00 STARTER MOTORS USED £55.00 TIMING BELT COVERS £5.00 TURBO HEATSHIELD £25.00 SUMP BAFFLES £30.00 SLANTED RADIATOR £350.00 LHD STEERING RACK £750.00     9 " REAR C/W PINION 4.4 £400.00   Drive Shafts FRONT ENDS GRP A £75.00 FRONT DRIVESHAFTS GPA £250.00 REAR DRIVESHAFTS USED £250.00   Steering-Front Suspension FRT ANTI ROLL BARS GPA £150.00 ANTI ROLL BARS GPA BLADE £75.00 FRONT HUB FLANGES USED £100.00 P.A.S. PUMP USED £100.00 P.A.S. BRACKET £80.00 P.A.S. PULLEY ALLOY £45.00 STEERING SHAFTS LOWER NEW £25.00 STEERING RACKS DRUM STICKS £25.00 GPA DRUM STICKS £150.00   GPA RS 500 PARTS   GP A RADIATOR £250.00 STEERING RACK £350.00 ALLOY FRONT TOP MOUNTS £50.00 FRONT DAMPERS £200.00 STEERING COLUMBE £150.00 REAR PROPSHAFT £50.00 REAR DRIVE SHAFTS £90.00 REAR DAMPER £200.00 FRONT ROLL BAR £150.00 REAR ROLL BAR £150.00       SAPPHIRE GPA APRTS ROLLING SHELL £1,500.00 MOUNTUNE ENGINE £4,500.00 RADIATOR £200.00 INTERCOOLER £100.00 THICK WALL FRONT DIFF £750.00 STEERING RACK £350.00 SUMP GUARD £100.00 ALLOY TCA £250.00 COMP STRUTS £150.00 ALLOY FRONT UPRIGHTS £450.00 GPA FRONT SHAFTS £250.00 315MM AP FRONT BRAKES £700.00 FRONT DAMPERS £200.00 FRONT TOP MOUNTS £50.00 STRUT BRACE £50.00 ECU £350.00 SPORT GEAR BOX £3,000.00 FRONT PROP £45.00 REAR PROP £55.00 GPA REAR BEAM £350.00 GPA REAR MAG ARMS £450.00 9" REAR DIFF £3,000.00 REAR DRIVE SHATFS £250.00 EXHAUST SYSTEM £100.00 REAR DAMPERS £200.00 FUEL PUMP £80.00 REAR TOE LINKS £100.00 285 MM AP REAR BRAKES £700.00     ESCORT GPA PARTS RADIATOR £350.00 LHD STEERING RACK £750.00   all parts are plus vat _________________ ATMsport LTD, Kelverdon , Essex, specialists in motorsport parts, e-mail sales@atmsport.com, web page www.atmsport.com tel 01376 585125 all prices are plus VAT   Last edited by andyt6762 on Mon Oct 04, 2004 10:40 am; edited 2 times in total Back to top   View user's profile Send private message
