Bdt Posted August 19, 2006 Posted August 19, 2006 -------------------------------------------------------------------------------- Gearbox,s 4WD Fix it big tooth GPN box new £3,250.00 R & D 6 speed dog gearbox fully rebuilt like new £4,200.00 Diff ‘s 9” CWP 4.6 NEW £300.00 Xtrac 7 ½” front diff and matching sump £1,400.00 9” FF Ricardo rear diff £2,950.00 7 ½” FF Ricardo front diff £1,500.00 6 ½” Plated front diff £750.00 7” plated rear diff complete £650.00 Complete new gear set 7 speed FF box £500.00 Twin paddle clutch complete £200.00 Escort Cosworth Gearbox Parts Front diff strengthening plate Kit £65.00 GPN Centre VC pumped up exchange £350.00 909 thick wall front diff £500.00 MANY OSBOURNE BIG TOOTH GEARS HELD IN STOCK WRC / GPA Parts LHD GPA rack used £700.00 4WD mountune big wing sump £280.00 Single paddle GPN clutch used £180.00 New LHD GPA Clutch cable £50.00 New RHD GPA Clutch cable £65.00 Escort full length sump guard £250.00 Pair alloy front uprights complete £1,050.00 Pair alloy TCA £500.00 Alloy front GPA top mounts a pair £200.00 9” Kevlar rear diff guard £75.00 Pair adj comp struts complete £300.00 .63 Turbo housing £150.00 GPA Square rear beam £450.00 Steel front GPA cross member £400.00 New GPA turbo with 247 £1,650.00 GPA / WRC lightened fly wheel £150.00 Alloy toe links £300.00 Pair 380mm x 34mm discs £200.00 Pair 355mm front discs and bells £180.00 Pair Gravel mag rear arms complete £1,400.00 P8 ECU with ALS £750.00 Complete 315mm AP brake kit £750.00 Clubman rear beam with rose jointed rear arms £800.00 Pair of 909 safari GPA spec rear arms complete £2,000.00 Pair front dynamic dampers complete £800.00 Wide track front shafts complete £250.00 Alloy header tanks £45.00 909 alloy gear box mount £150.00 Alloy 909 rear diff mount £100.00 909 steering arms £200.00 Pair Rose jointed TRE and drums £350.00 New 8 injector WRC inlet manifolds complete £480.00 New Pectel 8 injector looms £545.00 New weld on chassis engine mounts £450.00 Weld on rear roll bar mounts £195.00 Complete front / rear adjustable roll bar package POA RHD GPA caged Shell with all doors, bonnet, boot, spoilers, glass, and dash etc just painted (red and silver) £3,000.00 Wheels & tyres 7 x 15”raceline GPA 4 X 4 gravel wheels each £55.00 6.5 X 15” mag escort FWD RS2000 wheels each £55.00 8 x 16” OZ wheels GPA each £65.00 7 x 16” speed line wheels GPA each £65.00 8 x 16” original RS200 wheels each £150.00 6 x 16 snow wheels each £70.00 All plus vat TEL 01376 585125 or sales@atmsport.com Listed above is only a small number of parts we have in stock IF YOU DO NOT SEE WHAT YOU NEED HERE SEE OUR WEB PAGE WWW.ATMSPORT.COM COS it`s WORTH it!
WingDude Posted August 19, 2006 Posted August 19, 2006 Jeje, alt er ikke så gromt lenger når man betaler og aldri får det man betaler for. Dette firmaet har et temmelig dårlig rykte, styr unna sier bare jeg
M-ic Posted August 20, 2006 Posted August 20, 2006 Ooops! Jeg har akkurat bestilt noe greier til Escorten derfra, godt jeg ikke har betalt enda.
Mark1 Posted August 20, 2006 Posted August 20, 2006 jeg har lenge siklet etter mange av delene atmsport selger, men etter å enda ikke sett noe positivt skrevet på utenlandske forum om dette firmaet velger jeg å avstå. Skal man handle fra dem så vil nok tipset være å dra ned til de. WWW.NorskEscortRegister.Net Escort Mk1/Mk2 register
JHS Posted August 22, 2006 Posted August 22, 2006 Henger meg på med de andre her ja, ikke mye positivt og lese om det firmaet...Søk litt på passionford for og bekrefte dette for de som fortsatt er godtroende.
