Guest Erik Braseth Posted October 21, 2006 Share Posted October 21, 2006 Hei Fant dette på et annet forum: Hi. Another option I used with GT is to fit the complete exhaust from the Sierra donor car. It came with a Stainless mongoose exhaust, which fits absolutely perfectly around the rear section and diff etc, and only had to be lengthened by 15cm or so infront of the two silencers by Pipecraft to get it to fit. Even the rear mounts were in exactly the same place. The pipes on this one are 2.25in once they split off the downpipe, running into two separate silencers, they then join into a 3in pipe going to the single silencer at the back. So you could certainly use the rear secion of one of these exhausts for a V6. They come up on ebay all the time, and sound very sweet! Må vel være et slikt anlegg: ebay link Kanskje det hadde vært noe å hatt på bilen, selv om det ville vært enda tøffere med dobbelt hele veien Link to comment Share on other sites More sharing options...
Count Posted November 3, 2006 Share Posted November 3, 2006 Har det jeg, må lage noen overgangsmuffer fra 57mm til 2,25".Mangler også et par centimeter, men det er bagatellmessig.I tillegg må du lage et høyere feste til bakpotta.Funker som F mitt ihvertfall. 12m Super 24v Cosworth Prosjektet mitt Link to comment Share on other sites More sharing options...
