FOCUS Posted September 18, 2004 Share Posted September 18, 2004 Twin Engined Fiesta I started this project around three years ago with the intention of creating the ultimate Sports Libre hill climb car. The chassis is based on my own design, and features fully independent rose jointed suspension. Everything from camber to caster, antisquat and track are fully adjustable as is rear toe. Suspension features fully adjustable 2 ¼" Bilstein coil over units with adjustable bound/rebound. Internally the car is fitted with a fully welded multi point cage. Power originally came from two heavily reworked CVH turbo engines. Things have now progressed and is currently undergoing the fitment of two 400bhp YB cosworth engines . Intercooling is achieved by a huge front mounted intercooler (another NMS cosworth special) whilst the mid engine has a roof mounted intercooler with roof air scoops. Cooling is conventional up front whilst the mid unit utilises a sealed centre cavity, housing radiator and oil cooler rads, fed by 4 fans from roof mounted ducts. Air leaves the rear engine bay via huge vents cut in the rear tailgate and window. Clutches are competition AP's whilst the gearboxes are Quaife straight cut units. The front gearbox utilises a Quaife ATB differential whilst the mid mounted unit has a conventional plate type LSD. A great deal of engineering went into developing the gearshift, throttle and clutch controls and the end result is accurate, quick and simple. A single gear shift operates both boxes whilst the throttle and clutch pedals connect to a linkage box where the cable travel can be biased via variable pivots. This enables varying ratios of throttle between engines achieved from just one pedal, and allows the clutch biting points to be balanced. Styling wise the car features one off box arches adding 5 inches to each side. Wheels are 10X15 magnesium OZ rears and 8X15 fronts. Braking is achieved via AP billet 4 pots up front running 280mm discs with Cosworth vented rear disc setup. Bias is controlled by twin AP master cylinders and balance link. The car is prepared to the highest standards and is built to full race trim fitted with Lifeline plumbed extinguisher system. This car is still in development with all attention being focused during 2004 now that other projects are complete. Prosjektet er satt i gang hos Norris Motorsport i england Blue Oval Racer07 Mondeo Tdci Titanium Stv Link to comment Share on other sites More sharing options...
Guest pisko Posted September 18, 2004 Share Posted September 18, 2004 å kjære vene! Link to comment Share on other sites More sharing options...
RsTurboTaule Posted September 19, 2004 Share Posted September 19, 2004 ja hvorfor ha en cosworth motor når du kan ha to!! .. bedre med en cosworth motor baki en en bimbo,hehe 88 Escort RSTurbo Link to comment Share on other sites More sharing options...
Guest Slick Posted September 19, 2004 Share Posted September 19, 2004 Litt etterligning etter Suzuki sine modeller.. Sykt Link to comment Share on other sites More sharing options...
OleK Posted September 19, 2004 Share Posted September 19, 2004 å herregud...hehe...konge da:) Cosworth! Link to comment Share on other sites More sharing options...
OleK Posted September 19, 2004 Share Posted September 19, 2004 hvor fant du infoen? bilder?!?!!?!? Cosworth! Link to comment Share on other sites More sharing options...
FOCUS Posted September 20, 2004 Author Share Posted September 20, 2004 det var noe jeg kom over på hjemmesiden til norris motorsport Blue Oval Racer07 Mondeo Tdci Titanium Stv Link to comment Share on other sites More sharing options...
JHS Posted December 11, 2004 Share Posted December 11, 2004 Noe mer info om denne nå eller? Har en mk2 XR2 selv som jeg har ville planer for, men er gøy og se hva slags galskap andre driver med... Link to comment Share on other sites More sharing options...
