escort rs turbo Posted January 16, 2008 Posted January 16, 2008 (edited) såe hva tror gutta ang denne turboen kontra disse hær 2? Dual Ball Bearing GT25R Turbo assembly with internal wastegate assembly. .64ar turbine with 5 bolt exit. Very very Good response turbo for 4 Cyl applications. This turbo has a flow capacity of about 240HP. Turbine-Wheel: 53mm w/ 62 trim-Housing: .64 ar-Maps Compressor-Wheel: 54.3mm w/ 60 trim-Housing: .80 ar-Maps Turbo unit includes actuator and bracket. This unit is usually in stock and ships withing 1-2 days. Dual Ball Bearing GT28R Turbo assembly with internal wastegate assembly. .64ar turbine with 5 bolt exit. Very very Good response turbo for 4 Cyl applications. This turbo has a flow capacity of about 310HP. Turbine-Wheel: 53mm w/ 62 trim-Housing: .64 ar-Maps Compressor-Wheel: 60mm w/ 60 trim-Housing: .60 ar T3 series turbocharger 60 trim. 60 Trim T3 with .48 ar.. 250HP 4 Cyl. Standard T3 4 bolt inlet and T3 5 bolt discharge exhaust Edited January 16, 2008 by escort rs turbo -86 escort rs turbo-89 sierra cosworth-96 mondeo 4x4-10 fiesta 1.4tdci
OleK Posted January 17, 2008 Posted January 17, 2008 T3 series turbocharger 60 trim. 60 Trim T3 with .48 ar.. 250HP 4 Cyl. Standard T3 4 bolt inlet and T3 5 bolt discharge exhaust jeg har ihvertfall god erfaring med denne turboen på 1600rst, er vel en god del billigere enn de andre og? Cosworth!
RS 1000 Posted January 23, 2008 Posted January 23, 2008 såe hva tror gutta ang denne turboen kontra disse hær 2? 1. Dual Ball Bearing GT25R Turbo 2. Dual Ball Bearing GT28R Turbo assembly with internal wastegate assembly. Compressor -Wheel: 60mm w/ 60 trim3. T3 series turbocharger 60 trim. 60 Trim Hvis valget stod mellom disse 3 og penger og kulelager ikke var ett tema så hadde jeg valgt turbo nr. 2. Jeg mener at turbo nr. 1 er litt liten og som du ser har turbo 2 og 3 veldig like kompressorer (Sierra Cosworth 2wd), men ganske forskjellige turbiner. Turbo nr. 2 kan imidlertid leveres som "retrofit" dvs. med T3 turbinhus og da er den lettmontet på RST. Ikke glem at selv om de funker bra, så er T serie turboer gamle og utrangerte saker. Hovedproblemet med inkompetanse er at innehaveren sjelden er klar over dette selv. Vedkommende fortsetter derfor sitt virke med å ødelegge for alle dem som tar kontakt.
