Tommelom93 Posted June 17, 2016 Posted June 17, 2016 (edited) Hei. Jeg lurer på om det er mye arbeid med å bygge om til bremseskiver bak på Mondeo mk1 (2.0l 136hk). Jeg kunne tenkt meg å oppgradere bremsene til 2.5l V6. Mvh Tom Edited June 17, 2016 by Tommelom93 Ford Sierra '85 2.3 GL Ford Mondeo '94 2.0 GLX Bruksbil: X - Ford Fiesta '00 1.3 X - Peugeot 607 '01 2.2 X - Toyota Corolla '99 1.3 Terra X - Honda Civic '97 1.4S X - Ford Mondeo '05 1.8 Prosjekttråd til Sierraen. http://www.fordclubnorway.no/forum/topic/77263-min-ford-sierra-23gl-1985-modell/ Prosjekttråd til Mondeoen. http://www.fordclubnorway.no/forum/topic/79676-min-ford-mondeo-20glx-1994-modell/?do=findComment&comment=786642
packs Posted June 17, 2016 Posted June 17, 2016 Hei, vil tro mk3 mondeo bremser vil være en bedre oppgradering.kverna satta dette på en escort http://www.fordclubnorway.no/forum/topic/57867-escort-mk6-300mm-bremser-foran-m-mondeo-mk3-caliper/ v6 er vel 280mm og sikkert ikke like lett å få tak i. se dennehttp://www.fordwiki.co.uk/index.php?title=Upgrading_Brakes_-_Mk1_%26_Mk2" Upgrading Brakes For Mk1 & Mk2 Mondeos BackgroundThe Mk3 Mondeo has 300mm 5-stud disk brakes, whereas the Mk1 and Mk2 disks are 260mm (4 Cylinder) and 278mm (V6) and 4-stud. However, the Focus ST170 has 300mm 4-stud disks, which will also fit the Mk1 and Mk2 Mondeos. The ST170 calipers are cast out of a single piece, unlike the Mk3 Mondeos, which are cast out of 2 pieces and can be found considerably cheaper. So it would make sense that you can upgrade your brakes to 300mm ST170 disks and Mk3 calipers. Parts2x Mk3 Mondeo Calipers 2x 300mm ST170 discs 4x 3mm spacers 4x Bolts for the calipers - must be at least 3mm longer than standard caliper bolts, and high tensile Watch OutObviously, with bigger disks, this mod will only work if you also have larger wheels - remember, the calipers are not only going to be a greater distance from the hub, but they will also be 3mm further out. For example, this mod will not work with standard ST24 wheels, but should be fine with ST200 wheels. Most 17" wheels should also be okay. ------------------------------------------------------------------- Escort MK5a, 91mod, 2.0 zetec
dohcboy Posted June 17, 2016 Posted June 17, 2016 finner d meste på ebay http://www.ebay.co.uk/itm/FORD-MONDEO-ST200-2-5-V6-1996-2000-FRONT-REAR-BRAKE-DISCS-AND-PADS-SET-NEW-/280176379142?hash=item413bd04506:m:muAkjYQLuz7l6Ctd1MnnTEg http://www.ebay.co.uk/itm/MONDEO-MK2-ST200-FRONT-BRAKE-CALIPERS-CARRIERS-/152113876478?fits=Car+Make%3AFord|Model%3AMondeo|Cars+Type%3A2.5+ST+200&hash=item236ab18dfe:g:NxIAAOSwLnBXUSjMhttp://www.ebay.co.uk/itm/MONDEO-MK2-ST200-REAR-BRAKE-CALIPERS-CARRIERS-/152122009726?fits=Car+Make%3AFord|Model%3AMondeo|Cars+Type%3A2.5+ST+200&hash=item236b2da87e:g:EGwAAOSwnNBXWR9t http://www.ebay.co.uk/itm/Mk2-mondeo-pair-Rear-hub-knuckles-st200-st24-zetec-2-0-genuine-ford-disc-brakes-/272264798365?hash=item3f643f209d:g:dXYAAOSwAvJW9tVo framme veit æ ikke om du treng å bytt navan, men sansynligvis e d plug an play der Merkur XR4TI85 Sierra xr4x4 2.8i06 Focus ST89 Sierra 2.0 i cls ohc turbo 89 Sierra 2.0 i cls dohc 86 Sierra 2.0 isturbo
Jarl Posted June 17, 2016 Posted June 17, 2016 (edited) Linken til Escorten er vel for bremsene foran?Siden jeg har en Cougar tenkte jeg på om det kunne være like enkelt å bruke bakbremsene til den på Mondeo? Den har ventilerte 253mm skiver bak, 4x108 boltsirkel, og så vidt jeg vet er understellet på den likt med Mondeo mk2 (og dermed likt mk1 også?) så i teorien burde det være bolt-on.Ligger en delebil på Finn for tiden Slik ser det ut på den: Edit: Har sett på bildene i ebay-linkene i innlegget over, og det ser ut til at Cougar har bakbremsene fra ST200, så da burde det vel gå greit. Edited June 17, 2016 by Jarl 1
