hello, i saw FAST FORD NO. mentioned on a site i use,and decided to have a go using it
i like it very much and would like to use this oppertunity to say hi!
i got a Escort Cosworth lhd Wolf,and have been aware for many years that there is some
VERY fast fords in Norway ,i see quite a few cars in magazines over here in UK from Norway
i like the site B) cheeRS karl :) :)
hi Jensrud and RSCOSWORTH, yeah we got some fast Fords but you have fast drivers too
when i was a kid we watched Rallycross on the telly,and i saw Martin Schanche regularly
in first the ZAKSPEED escort then the GARTRAC escort, i am going to try sticking a photo up of my car :huh: :D :)
hi there cossieman!! sorry Jensrud i am poor on the computer i need to have a fiddle with it
as the photos look ok on my file and crap when i try to post it.
Mind you i never tried to put photos up before :ph34r: :D
Did you take the pictures with your phone...? :blink:
welcome to the site m8... great to se some peeps from other contry`s here to =)
your cossie looks great but the pic`s are abit crappy tho :P ;)
what the spec`s, standar wolf setup?
Edited by hår ball
hi har ball and Alex!!!
my Cozzie has got a alloy breather separator,3 bar map sensor,arp stud and nut kit,
pipercross big cone air filter,group a head gasket,baily dump valve,uprated actuator
and a sign in the glove compartment which reads luftdruck vorne 2.8 bar hinten 2.7 bar,dont
know what it means exactly,turbo pressure maximum??
also has a big old stainless exhaust,koni suspension,wheel spacers and FORD MOTORSPORT
front and rear alloy strutbraces,and has had somthing done to the gearbox as this COZZIE
has the best closest gear change i have ever feelt on a MT75.
also first COSWORTH i have had with heated RECARO chairs :o :P ,
sorry about the quality of the pictures JHS must of been taken with a box brownie :blush: :blink:
I'm guessing luftdruck vorne 2.8 bar hinten 2.7 bar means:
Airpressure front 2.8 bar rear 2.7 bar ;) Most likely to be your wheels then...
Does it have Wolf exhaust...? Where did you buy the car? Tried to track down previous owners to find out some history?
have had a look at the exhaust system,and other than the fact it has two pipes sticking out of the
back bumper like a double barrel shotgun OO, i can not see a makers mark.
this car belonged to a FORD main dealer or a Handler in GERMANY for about 7or 8 years after
they registered it new, they didn't use it very much, it must be strange owning a top of the range
FORD, and stamping your service history for yourself.again if i spoke GERMAN i would get in touch
but i find it :blush: a bit embarresing when you can not make youself understood,
did WOLF do any thing with the gear shift or transmission ?
oh and thanks for the tyre pressure info, we do it over here as psi :blink: :D
i got the car from a COSWORTH specialist in of all places NORTHHAMPTON
must of been meant to be,assembled at KARMANN GERMANY, sold in GERMANY then came over to UK
to the home of COSWORTH :) :) :)
Doesnt sound like you've got the Wolf exhaust then. And as far as I know Wolf didt change anything regarding gearshift or transmission...
Have you got the name of the Ford dealer? Try sendig them a email in English, I'm sure they'll understand what you write... ;)
