escortcosw Posted November 8, 2007 Share Posted November 8, 2007 Hei kan noen hjelpe meg har kjøpt en frammdiff quaife 6.5..'den skal være med forserket hus....hvordan kan man se dette ev merker hvor...kan man måle det?ev hvor...hva skal ett forsterket hus være merket med osv.....Vil ikke montere den før jeg vet at alt er som det skall...På forhånd takk... Link to comment Share on other sites More sharing options...
Guest karl Posted November 8, 2007 Share Posted November 8, 2007 (edited) se forskjell her. du ser lett gods tykkelse forskjell.venstre er en motorsport... Edited November 8, 2007 by karl Link to comment Share on other sites More sharing options...
escortcosw Posted November 8, 2007 Author Share Posted November 8, 2007 se forskjell her. du ser lett gods tykkelse forskjell.venstre er en motorsport... Tusen tusen takk for det raske svaret,,,hadde du vert her skulle du fått en klem Link to comment Share on other sites More sharing options...
escortcosw Posted November 8, 2007 Author Share Posted November 8, 2007 Tusen tusen takk for det raske svaret,,,hadde du vert her skulle du fått en klem Vet du åssen olje som skal være på denne qvifev diffen? Link to comment Share on other sites More sharing options...
Cosworth Racing1 Posted November 8, 2007 Share Posted November 8, 2007 Oljen du skal bruke heter: MobilMobilubeSHC-LSGear OilSAE 75w-90 Dette står utenpå flasken.. 2008 VW Transporter 2,5 4motion1991 Sierra Cosworth 4x4 Link to comment Share on other sites More sharing options...
Janna Posted November 8, 2007 Share Posted November 8, 2007 Silkolene Silktran SYN 75W / 90 synthetic gear and transmission Oil is a fully synthetic gear lubricant for manual transmissions and final drive units in high performance vehicles. Designed to meet or exceed the most stringent gear oil criteria, Silkolene Silktran SYN incorporates the very latest additive and synthetic lubrication technology and is recommended for use wherever a multigrade API GL5 lubricant is specified. Silkolene Silktran SYN operates over a wide temperature range and gives true “stay in grade” performance. Silkolene Silktran SYN extends component life and enables optimum power release, even at low temperatures. Silkolene Silktran SYN is recommended for-Quaife dog engagement gearboxes and gearkitsQuaife reversing boxQuaife ATB differentials QUAIFE DOES NOT RECOMMEND THE USE OF AUTOMATIC TRANSMISSION FLUID WITH OUR PRODUCTS. Bilder av mine tidligere cosworth http://www.fordclubnorway.no/forum/topic/12870-alle-mine-biler/ Link to comment Share on other sites More sharing options...
escortcosw Posted November 8, 2007 Author Share Posted November 8, 2007 Silkolene Silktran SYN 75W / 90 synthetic gear and transmission Oil is a fully synthetic gear lubricant for manual transmissions and final drive units in high performance vehicles. Designed to meet or exceed the most stringent gear oil criteria, Silkolene Silktran SYN incorporates the very latest additive and synthetic lubrication technology and is recommended for use wherever a multigrade API GL5 lubricant is specified. Silkolene Silktran SYN operates over a wide temperature range and gives true “stay in grade” performance. Silkolene Silktran SYN extends component life and enables optimum power release, even at low temperatures. Silkolene Silktran SYN is recommended for-Quaife dog engagement gearboxes and gearkitsQuaife reversing boxQuaife ATB differentials QUAIFE DOES NOT RECOMMEND THE USE OF AUTOMATIC TRANSMISSION FLUID WITH OUR PRODUCTS. Hei vet du vor jeg kan få tak i den olja? Link to comment Share on other sites More sharing options...
Cosworth Racing1 Posted November 8, 2007 Share Posted November 8, 2007 Er vel tilsvarende den jeg bruker... Står bakpå flasken "Helsyntetisk gearolje med enestående ytelse- for smøring av differ med limited slip i kommersielle kjøretøy, anleggsmaskiner og personbiler" 2008 VW Transporter 2,5 4motion1991 Sierra Cosworth 4x4 Link to comment Share on other sites More sharing options...
Guest Ford Gnomen Posted November 10, 2007 Share Posted November 10, 2007 Olje Link to comment Share on other sites More sharing options...
MacGyver Posted November 10, 2007 Share Posted November 10, 2007 håper jeg ikke ødelegger topicen her men.. Kan noen fortelle meg hvilke oljer jeg trenger til Escort Cossien min?Tenkte å bytte ut alt av olje, i motor, girkasse, differ.. Og hvordan gjør jeg det? (ser for meg at det er en liten utforfring å bytte diffolje?) Er ganske grønn, men håper noen vet - Olle - sykler til arbeid Link to comment Share on other sites More sharing options...
bige Posted November 10, 2007 Share Posted November 10, 2007 det med oljer er det stooore tema her på forumet Til motor kan du kjøpe rådyr olje og bytte sjelden eller biltema synt og bytte ofte (2500km) med filter Det som ødelegger motor og oljen er høye temp derfor mener jeg olje temp måler er ett must om du kjører inspirert .Sammen med en olje kjøler med termostat .front diff må du ta av "platen" i bunn - som er noe griseri - bruk god synt gir olje .Samme bak - der er det plugg og skru ut - du må suge ut oljen (stiga rider gressklipper har en fin suger )sentral diff er det noe mere arbeide( må også suges ) - automat kasse olje - les helst manual - den skal IKKE fylles helt opp .. Link to comment Share on other sites More sharing options...
tommy w Posted November 10, 2007 Share Posted November 10, 2007 senterdiffen er avtapping i bakkant.. Sierra Cosworth 4x4 Limited Edition 73/700Escort CosworthEscort CosworthFord SVT LightningMB Vito 2013 Link to comment Share on other sites More sharing options...
MacGyver Posted November 10, 2007 Share Posted November 10, 2007 det med oljer er det stooore tema her på forumet Til motor kan du kjøpe rådyr olje og bytte sjelden eller biltema synt og bytte ofte (2500km) med filter Det som ødelegger motor og oljen er høye temp derfor mener jeg olje temp måler er ett must om du kjører inspirert .Sammen med en olje kjøler med termostat .front diff må du ta av "platen" i bunn - som er noe griseri - bruk god synt gir olje .Samme bak - der er det plugg og skru ut - du må suge ut oljen (stiga rider gressklipper har en fin suger )sentral diff er det noe mere arbeide( må også suges ) - automat kasse olje - les helst manual - den skal IKKE fylles helt opp .. Takker!.. Men en ting er jo å tappe ut, men å fylle på igjen (er vel kanskje litt trixy det også?) sykler til arbeid Link to comment Share on other sites More sharing options...
Guest mazdafun Posted November 10, 2007 Share Posted November 10, 2007 en gammel ketchup-flaske og en halv meter spylevæske-slange Link to comment Share on other sites More sharing options...
Slåstad RS Posted November 11, 2007 Share Posted November 11, 2007 Hva skjer hvis du fyller helt opp på senterdiffen? Aldri noe godt uten at det er galt for noe. Link to comment Share on other sites More sharing options...
grcossie Posted November 12, 2007 Share Posted November 12, 2007 Fordelings kassa har også nivå plugg Link to comment Share on other sites More sharing options...
