Tommen Posted January 2, 2013 Share Posted January 2, 2013 Jo det kan stemme.. hjernen er ikkje heilt med etter Jula The Golden era.. 1986-1987-1988 Link to comment Share on other sites More sharing options...
Asil Racing Posted January 2, 2013 Share Posted January 2, 2013 Ny eier skulle visst betale 610.000 kr. BN registrert. Vet ikke om noen hvite RS500 her nei da vet jeg om en gateregga org rs 500 , som kan sikkert gå for 110 tusen mindre Link to comment Share on other sites More sharing options...
Tommen Posted January 2, 2013 Share Posted January 2, 2013 (edited) bil nr 1 og 4** finns i norge , bil nr 5 blei høgd i sarpsborg , kh turbo hadde 29/35 den 4 er regga .mulig en i stavanger ennå. Fikk akkurat beskjed om at det er 8 ekte RS500 i norge pr dags dato..Det var chassi nr 5 i rekken men bil nummer 122 som blei stjålet å hugget. KH hadde 026. Edited January 2, 2013 by Tommen The Golden era.. 1986-1987-1988 Link to comment Share on other sites More sharing options...
bige Posted January 2, 2013 Share Posted January 2, 2013 (edited) her er dele listen og dele nr til andre deler på RS500 enn vanlig vinge coswFinnis Code Description9092625 Heatshield – turbo /abs pump9092627 Heatshield – hood top9092386 Hose – amal valve – w/gate9092635 Hose – valve to air/cleaner9092425 Hose – turbo charger outlet to intercooler9092426 Hose – intercooler to throttle hsg9092427 Hose – air cleaner to turbo9093096 Hose – water turbo cl9092972 Kit aperture grille assy. – RH9092971 Kit aperture grille assy. - LH9092679 Decal – body side wing front – LH9092680 Decal – body side wing front - RH9092681 Decal – body stripe (6 metres per car req`d 1) 1metre9092793 Decal – RS500 – rear9092723 Bumper front airdam – moonstone9092722 Bumper front airdam – black9092724 Bumper front airdam – white9092733 Air splitter support front LH – black9092732 Air splitter support front RH – black9092692 Protection sheet – rr spoiler – RH9092693 Protection sheet – rr spoiler - LH9092735 Spoiler rear lower9092737 Rear aerofoil – upper – black9092721 Rear aerofoil – upper – white9092720 Rear aerofoil – upper – moonstone9092786 Exhaust downpipe turbo to bulkhead9093013 Thermostat 9093022 Plenum – intake elbow9093025 Plenum – cover9092924 Turbo charger9093037 Oil pump assy9093039 Water pump assy volume prod9093095 Turbo damper rework kit9093086 Damper assy turbocharger1638293 Door mouldings 1638294 Door mouldings 1638295 Door mouldings 1638296 Door mouldings 1638297 Door mouldings 1638298 Door mouldings 9092903 Convoluted tube – hose protection 120mm9092902 Convoluted tube – hose protection 100mm9093286 Brkt. Inner pivot ext. hsg rear susp LH9093289 Brkt inner pivot ext. hst rear susp RH9092605 Seal – intercooler to radiator upper9092606 Seal – intercooler to radiator lower9092456 Bracket – intercooler to rad to body LH9092457 Bracket – intercooler to rad to body RH9092432 Hose – header tank9092427 Shield – radiator9092423 Hose radiator – lower9092655 Cover plate bumper reinft9092424 Hose – air bypass valve9092471 Pipe – air bypass valve9092678 Intercooler assy9092390 Air cleaner lid9092625 Tube – air cleaner intake9092454 Plate alt. mtg.9092458 Arm – alt belt adjust9092690 Bracket – map sensor mtg.9092698 Ecu – module9092671 Bracket – horn mtg.9092672 Bracket – horn mtg.9092684 Nut – m5x30x10mm af9092708 Spacer rad mtg9092674 Edge clip9091522 Hose tie 200mm x 2.5mm9092689 Hose tie 390mm x 4.6mm9092702 Hose clamp 60 – 809092650 Engine assy hot tested9092704 Hose clamp 70 – 909092695 Hose clamp 25 – 401650573 Hose clamp 30 – 459092718 RS500 original cylinder block9093002 Idle speed regulator retainer9093003 Idle speed regulator9093004 Throttle position switch1640040 Sender – water temperature9093012 Water outlet & thermostat housing9093014 Bracket – throttle cable mounting9093018 Throttle body assy.9093021 Gasket – throttle body / plenum9093026 Gasket – lower plenum9093027 Inlet manifold9093028 Fuel rail assy – upper9093030 Regulator – fuel pressure9093033 Gasket- inlet manifold9092925 Oil pump inlet / cooling rail assy.9093040 Spacer – thermostat9093041 Gasket – thermostat elbow9093042 Spacer turbo oil pipe / cam cover9093043 Pipe – turbo oil feed9093044 Elbow – thermostat housing9093045 Fuel rail assy – lower9093047 Fuel transfer hose9093048 Hose – lower fuel rail / relief valve9093049 Moulded pipe – throttle body / plenum elbow9093050 Hose – water pump / thermostat housing9093052 Gasket – thermostat housing9093053 Pipe – heater to water pump9093054 Hose – heater to water pump9093056 Hose – water pump stub.9093083 Exhaust valve9093093 Pipe – water o/l turbo9093094 Hose rad overflow9093095 Clip – water pipe1514328 Spacer9093065 Inlet pipe – water cooled housing9093071 Gasket – oil pump body / pickup flange9093072 Plug – fuel press reg.9093074 Piston say c/w fins, circlip, rings (rs500 block only)9093073 Sheath – heater return pipe9093077 Rubber hose valve / plenum9093079 Flexi pipe – fuel rail pressure9093081 Service cylinder head assy9093000 Misc hardware rebuild kitM51870025 Spirol pin 5mm x 12mm mbk – inlet manifold to head1473188 Screw m5 x 10 lg hex head grade 8.8 airbleed – water out1613296 Bolt m6 x 55 hex head grade plated – turbo clamping damper6163723 Copper washer m6 12.5 x 6.4 x.8 – airbleed water outlet hsg.1503011 Bolt m6 x 80 hex head grade 8.8 plated int. elbow to plenumMS1870035 Spirol pin 2.5mm x 8mm mbk idle speed valve to intake elbowM51105025 Screw m5 x14 cheese head slotted plated – idle valve to intake elbow206416 Spring washer m5 single coil idle speed valve to intake elbowE602214572 Screw m10 x 55 hex. Head grade – water pump to headH88H9E499AA 90 degree male elbow 3/8 nptf ybd – thermostat housingM518055245 Screw m6 x 25 s.c.h. grade 12.9 e-coated – tur oil pipe clip to cam cover9091752 Screw m8 x 25 s.c.h. e-coated therm hsg to cyl headM51863855 Red cap – transportation – throttle housingM51863855 Red cap – transportation – turboM51601615 O ring – throttle switch to throttle bodyM51601615 O ring – idle speed valve to intake elbowM51601625 O ring - idle speed valve to intake elbow M51830545 Washer square throttle switch mountingM51106015 Screw and integral washer throttle switch mountingM51850155100 Jubilee clip – size 2a 32mm – 50mm1519545 Insulator – intercooler to top chassis mounting6170132 Fuel clip1579614 Rivet 4.0 x 8.9 rear aerofoil to tailgate1467848 Washer flat air splitter to bumper1571868 Nut nyloc air slitter to bumper6112228 Nut – m10 engine mount to insulator1494742 Screw m6 x 16 intercooler to radiator1579565 Nut spring intercooler to radiator1475363 Bolt m8 x 40 hex head intercooler to chassis1471553 Washer flat intercooler to chassis1640474 Clamp – 8-10 emission pipe1629583 Nut m12 rear suspension inner pivot to wishbone1955305 Nut m10 turbo to muffler inlet pipe6159481 Bolt – m10 x 50 exhaust pipe to convertors1509658 Strap secondary engine loom Edited January 2, 2013 by bige Link to comment Share on other sites More sharing options...
Tommen Posted January 2, 2013 Share Posted January 2, 2013 her er dele listen og dele nr til andre deler på RS500 enn vanlig vinge cosworth Geek! neira! stilig The Golden era.. 1986-1987-1988 Link to comment Share on other sites More sharing options...
r2d2 Posted January 4, 2013 Share Posted January 4, 2013 d stemmer no d at den eneste regga rs500 i norge holder til i nord. kjenner vedkommende, å bilen er mere strøken under enn over Er det en av dei som var i Fredrikstad? Link to comment Share on other sites More sharing options...
Smistad Posted January 12, 2013 Author Share Posted January 12, 2013 Da er bilen solgt og den befinner seg i Haugesund trakter, har dessverre ikke mer info Busskort. Link to comment Share on other sites More sharing options...
