cbp
Everything posted by cbp
Autronic SM2 er et topp system og gir deg nok fler muligheter en du kommer til å bruke. Nypris På SM4 er ca 18000,- inkl mva og gir deg enda noen muligheter du nok heller ikke kommer til å bruke. Så det får nesten være opp til deg om du synes SM2 er verdt kronene. Jeg for min del ville nok ha slått til da dette systemet gir deg alt du trenger og enda litt til, husk at SM2 var toppmodellen før SM4 kom. Men sjekk gjerne opp vilken chip den har da dette styrer hvilke funksjoner den har, det samme med hvilken mapsensor som sitter i den. Her har du litt mer info om SM2.. SPECIFICATION FOR MODELS SM2 OVERVIEW The Autronic SM2 Sequential Engine Management Systems are versatile engine management controls for all engine performance upgrades. Their sophisticated features allow these products to provide performance that rivals even the most expensive European systems costing 3 to 10 times more. Included are features normally only found in Formula 1 level applications, yet this system has the flexibility to be used by the every day engine tuner for almost any high performance upgrade. A user friendly ‘IBM’ compatible lap-top program allows the user to select the degree of sophistication required for each application. This program, in combination with the intelligence with the management system, allows the user to select the finest calibration detail required to match the application, in an absolute minimum of time. This program provides the means of interrogating the engine management system enabling speedy fault diagnosis and calibration. (An alternative low cost hand held calibrator may be available in future). The SM2 system combines a sophisticated engine management system with the convenience of a powerful data logger that can simultaneously log both engine operation and numerous other vehicle functions. USAGE These systems can cater for the requirements of virtually any spark ignition engine, including the following:- High output supercharger or turbocharger engines, with either multi point and/or centre point injection. Rotary (Wankle) and two strokes engines. Engines having uneven firing sequence such as 2 and 4 cylinder ‘V’ configuration motorcycle engines and V6 motor vehicle engines. IMPORTANT: Please note that this product is intended for high performance motor sport applications and compliance with statutory regulations when used on public roads cannot be guaranteed. FEATURES Eight injector drivers for full sequential operation on engines up to eight cylinders. May be set for ‘semi-sequential’ operation on engines having more than 8 cylinders, eg:- 12 cylinder engine using 6 groups of 2 cylinders. All injector types catered for (0.9 ohm to 16 ohm coil resistance). Specify unit fitted with optional high current injector drivers for 0.9 ohm or twin injector applications. User choice of manifold absolute pressure or throttle position as engine load input. Internal absolute pressure sensor for simplified installation 0 to 200Kpa (0 to 29.4 PSI) and 0 to 300Kpa (0 to 44.1 PSI) available from stock 0 to 450Kpa (0 to 66.1 PSI) available on request. Single coil distributor, twin coil distributor or multicoil distributor-less ignition configurations are possible on most engines. Closed loop (feedback) boost pressure control for turbo charged engines with multiple calibration curves selectable by switch input or road speed (eg:- lower boost curve for use in low gear). Closed loop (feedback) idle speed control. Exhaust oxygen sensor input for sensing air/fuel ration. Can also be used with the AUTRONIC Wide Range Air/Fuel Ratio Sensor to monitor air/fuel ration in motor sport application, or can be used for feedback control of air/fuel ratio for use with catalytic converter (feature available on request). Diagnostic/Error indicator of sensor or ECU fault conditions with memory for detection of intermittent fault conditions. Measurement of and correction for exhaust back pressure (applicable to turbo charged engines). Control of engine cooling fans and coordination with air conditioner operation. Programmable on/off output for solenoid or relay driving that operates according to engine speed and load. (eg:- can be used for gear shift control or light, over rev indicator, inlet camshaft timing selection or control of a supplementary electric fuel pump that augments mechanical fuel pump delivery at low engine rpm only). Precise spark advance control strategy for both static and dynamic operating conditions. Unique calibration strategy allows accurate control of fuel delivery under both acceleration and deceleration. User selectable spark and fuel delivery strategy for abnormal engine operation conditions to minimise possibility of engine damage whilst still maintaining engine operation. (eg:- over heated or over boosted). Comprehensive limp-home functions with selectable default settings that ensure engine operation can continue after sensor failure has occurred. User defined proportional output function that can be used for additional functions as outlined in 10 above or for a more sophisticated control function such as servocontrol of auxiliary butterfly for turbo charged applications requiring precise throttle control and minimum turbo lag. Full compensation of engine control parameters for engine operation at any altitude (fuel delivery, ignition timing and boost pressure). Adaptive learning (with memory) to minimise the number of user setups required and to provide optimal control of air/fuel ratio, boost pressure and idle stability. Rev Limiter with a soft characteristic that uses a combination of fuel delivery and spark control. Fuel pump safety shut-off. Pump stops 3 to 4 sec after the engine stops. Bi-directional input/output line for simultaneous connection of remote adjusting unit and combustion knock detection unit. The adjusting unit allows rotary switch offset corrections to be made to spark timing, mixture strength and boost pressure settings (adjusting unit available Q4-93, Knock control Q1-94). Standard unit is light weight/compact yet has sufficient drive capacity for high power continuous duty applications (one unit suitable for all applications from motor cycle to large capacity twin turbo engines). User configurable data logging of up to 17 channels with the selected channels being sampled as fast as50 times per second. With 128K bytes of non volatile memory (Model designation SM3). Auxiliary analog input channels (4 of) for user defined data logging Auxiliary digital input channels (2 of) for user defined data logging Optional interface unit to allow sequential operation without the need for separate crank/camshaft sensors or special multi-sensor distributor (P/N:-ADP102 available Q3-93). Fuel used pulse output to electronic or electro-mechanical counter with resolution of 0.1 litre (or use with trip computer). Remote monitoring of all functions using optional telemetry adapter (available Q2-93). ECU can perform simultaneous logging and telemetry. INTERFACE REQUIREMENTS FOR MODELS SM2 INPUTS Sensors Ignition input Hall effect (or Magnetic Reluctor with optional interface adapterP/N:-"ADP101"). No. 1 cylinder reference (or Magnetic Pick-up with optional interface adapter P/N:-"ADP101"). Road speed input. Hall effect (or Magnetic Reluctor with optional interface apapter P/N:-ADP101"). Turbo speed input. Magnetic Reluctor (must use optional interface adapter P/N:- "ADP101"). Barometric pressure (internal to ECU). Manifold pressure (internal to ECU). Throttle position. Intake air temperature. Engine coolant temperature. Exhaust back pressure (optional) Exhaust oxygen (or optional AUTRONIC Wide Range Air/Fuel Ratio Sensor). Auxiliary Air conditioner request. Boost curve select. Adjustments Idle mixture trim. (Internal to ECU and screwdriver adjustable from outside). OUTPUTS Main 8 off injector driver (optional 2 injectors per driver). Ignition output: Single coil high energy ignitions: Bosch 7 pin, Mitsubishi 3 pin. Autronic Capacitor Discharge Ignition. MSD 6A c. (4 outputs are available allowing multi coil distributor-less ignition for application on engines up to 8 cylinders.) Auxiliary Fuel pump/injector fuel shut off safety relay. Air conditioner clutch relay. Engine/Air conditioner cooling fan relay. Engine cooling fan relay. Idle speed actuator (variable duty cycle single pole type eg:- Bosch). Turbo charger waste gate control valve (SEM, most OEM types or AUTRONIC low or high capacity). Turbo charger auxiliary butterfly control motor. Spare duty cycle output with user defined characteristics. Fuel used pulse output (for trip computer function). SERIAL I/O Communication with "IBM’ compatible computer for calibration, fault diagnosis and data logging (Some markets require special adaptor). SPECIFICATIONS FOR MODELS SM2 AND SM3 MICROCOMPUTER 16 bit running @ 16MHz SUPPLY VOLTAGE Normal operation 6.2v to 23V DC continuous Safe Limits +/-24V (5 min) +/-80V alternator load dump (0.5 sec) +/- 1000V inductive spike (10 usec) CURRENT DRAIN @ engine idle <1 amp @ max engine load <16 amp (less depending on injector type and number) OPERATING TEMPERATURE RANGE Min Max -40° C +85° C ENGINE CYLINDER NUMBER SETTINGS Number of cylinders 1,2,3,4,5,6,7,8,10,12,14, and 16 ENGINE RPM RANGE 0 to 30,000 rpm 0 to 16,000 rpm 0 to 15,000 rpm Engines up to 4 cylinders Engines 5 to 8 cylinders Engines 10 to 16 cylinders INJECTION DURATION TIMING Min Max Accuracy Setting resolution 0.7 msec 30 msec +/-<(10sec + 1% 0.1% approx INJECTION TIMING Range Accuracy Setting resolution 0 to 720° (crank angle) +/-<(1.4° + 0.3 msec) 2.8° IGNITION TIMING Advance range Accuracy Setting resolution 0 to 45° (crank angle) +/- 0.2° (crank angle) 0.5° (crank angle) FUEL DELIVERY AND IGNITION MAPPING No. load sites No. rpm sites 16 (max) Both load and RPM sites 32 (max) are freely selectable SIZE AND WEIGHT L* W* H 190* 190* 38mm 235* 190* 38mm (overall, including mounts) 1.35kg CONNECTORS 52 way "AMP’ socket using 3 separate plugs 10 way high current plug 18 way low current plug 24 way low current plug Miniature mic plug (3.5mm stereo) 3 way for communication with lap top computer
cosworth deler selges. 600hk motor,fix it,quaife,wilwood
cbp replied to just4fun's topic in Deler selges
http://www.fixittransmission.com/ -
Hva slags TSW felger er det snakk om? -
Ingen som vil en skikkelig grom Intercooler? Intercooleren er lavet av Hyperflow i Australia. Ikke noe kina greier...
Ny og ubrukt intercooler til Escort Cosworth selges. 62mm register, intercooler er bolt on, det medfølger komplett monteringssett. Pris 3800,- + frakt. Christian 45021515 Akershus
Du tar nok muligens feil der: Maxima Racing Oils Norway Tom Jorstad T: 011-47-85-02-7911 F: 011-47-85-03-5491 Fagernesfeltet 3536 Noresund Norway . . maxima.racing@norway.online.no
Grunnen til at jeg vil anbefale å sette dumpventilen før intercooler er at da slipper intercooleren å kjøle ned luft som ikke vil bli brukt av motoren. La intercooleren kun kjøle ned luft som blir brukt av motoren, hvis intercooleren hele tiden skal kjøe ned en masse luft som ikke brukes av motoren faller effektiviteten på IC drastisk. På en bil som kun går på gata så er dette kanskje ikke så farlig, men til banekjøring så vil det helt klart påvirke... Skrev ikke det heller.. men endel dumpventiler er laget slik at luften kan ventileres tilbake til noe.. originalt på cosworth så er dette tilbake i luftfilterboks. Skjønner?
Vil anbefale deg å ha dumpventilen før intercooler men ikke la luften gå inn i slangen fra luftfilteret igjen.
Eeeh? EBC Greenstuff er en kloss for gatekjøring og har IKKE noe på en bane å gjøre. Skal du dit skal du bruke Yellowstuff eller til nød Redstuff Ceramic. Er det bare banekjøring man driver med finnes også Bluestuff som er en ren racingkloss.
Selger et grenrør som er laget som en erstatning for original turbomanifold på en 4x4 cosworth motor, dvs at det er bolt on og passer T3 og T34 turbo. Alle rørene møtes i kollektoren. Står på original plass så det passer ypperlig hvis man skal sette en Cosworth motor i en bil hvor det er trangt om plassen. Grenrøret er laget i 304 rustfritt stål og er blankpolert. Dette er nytt og ubrukt, leveres med eksospakning, turbopakning og pinnebolter til turbo innfestningen. Selges 4000,- 45021515 Akesrhus Christian.
Denne Pumaen er designet av Mike Endean, Mike startet XTRAC i sin tid og bygde girkasse og differ til Martin Schanche sin Escort MK3 Rallycross bil. Denne Gould bygde pumaen har girkasse og drivverk designet av Mike. Motoren er en variant av Ford RS200 BDT på 700hk.
Her denne fortsatt liggende hvis noen er på jakt etter en slik.
Solgt.
Det er tatt ut noe mer en 550 hk på standard råder. Veiva bør ikke byttes med mindre du skal endre slag eller ta ut 1000hk Men skal motoren trimmes så er det jo normalt å bore opp noe og det vil være naturlig å bytte stempler. Burton leverer Accralite stempler i flere størrelser til Cosworth. Det er flere som kan levere stempler og diverse til Cosworth men ofte må du selv specce hva du vil ha da de ikke lager spesifikt til Cosworth.
Aner ikke hvor mye plass det er i en 940, men her har du endel mål så du kan måle litt selv. Høyden fra bunn av IC til topp av IC rør er 44 cm. Bredde på bredeste punkt av selve IC´en er 76,5 cm (ikke med festebraketter). Lengde fra topp av register til topp på festebrakett er 10,5 cm. Lengde fra topp av festebrakett til bunn av IC er 21 cm. Inn og ut rør stikker 9 cm ut fra IC. Bredde på festebraketter er 9,5 cm. Bredde på IC i bunn er 68 cm. Håper dette hjelper. Mvh Christian
Noen som vil ha en grom intercooler? Kom med bud.
Solgt.
Er ikke med vifter og sensor.. men disse passer rett på, beklager hvis det var lett å misforstå.
Den er 100% bolt on ja, med vifter og sensor. Frakt er ca 200,-. Sender ikke i oppkrav, kun forhåndsbetaling. Sender samme dag penger er på konto. Mvh Christian
Ser helt klart at forskjellen på deg og meg er at jeg har barn og kone, det har ikke du! Når man får det så blir det viktigere en alt...selv overtid for å tjene mest mulig penger
Gir deg 200,- så er du kvitt den
