JonV
Everything posted by JonV
Er egen dieselpumpe på webasto ja. Men at den ikke tenner kan og tyde på f.eks glødeplugg.
Hei noen som vet hvordan jeg finner ut om jeg kan montere ryggekamera på min radio/bil ? Sitter orginal radio i bilen men vil gjerne ha ryggekamera
du kan få hele for 1500,- + evnt frakt Det er da inkl potta og
Vil heller tro det er ledningsnettet MYE byttet på alle ford modeller.
Finner endel på U3000 og den sier hjernen i webastoen. Code: U3000 - Control Module Subcode: 49 - Internal Electronic Failure Status: 68 Module: Auxiliary Heater Control Module Diagnostic Trouble Code details Perform these checks Check the %%h(ABS)(EB9F) module ground connections. Check the %%h(ABS)(EB9F) module power supply connections. Check the condition of all cables and connectors for broken cables, damaged insulation, contamination, water ingress and loose connections. Check the %%h(ABS)(EB9F) module connections for damage, water ingress or corrosion . If any contamination is found, clean the connector and %%h(ABS)(EB9F) module terminals. Check the connector for damage or contamination. Check for an open circuit in the wiring harness. Check for a short circuit to the ground or battery. Check the condition of all cables and connectors for broken cables, damaged insulation, contamination and loose connections. Make sure there is no continuity to ground or supply. Select Self-Test in the toolbox menu, select Chassis -> Braking -> %%h(ABS)(EB9F) or %%h(ESP)(18718), depending on the system. Perform an On Demand Self-Test. If the %%h(DTC)(FA18) is ODDTC and not historical or continuous, do not delete the DTC and replace the %%h(ABS)(EB9F) module. If the %%h(DTC)(FA18) is %%h(CMDTCs)(186CA) and historically this may be an intermittent fault, the cause of which cannot be identified at this time. The customer should return the car should the fault reoccur noting the conditions at the time of the failure like the speed and application of the brakes. Skulle du trenger deler fra en så har jeg en enhet jeg evnt kan selge da jeg bytta hele i min bil for litt siden. Feil på den jeg bytta ut er Glødepluggen, var ihvertfall det DTC sa.
Hei alle sammen. Nå etter å vært lei av kun 1 dimmet drl på parklys tenkte jeg at jeg skulle fikse. Skaffet lampe og tok med kjent svakhet, altså ny kabelmatte til lamper samt parksensorer. Når da alt var byttet så var jaggu venstre "park" drl fremdeles død. Det er ingen feilkoder på bilen, lest av med forscan. Er det noen her inne som har noe next step på hvor hva som kan forårsake dette ? Begynner å bli lei av 1 lys foran når hovedlysa skrur seg på.
Er samme varmer i Mondeo, Smax, Galaxy Det er en Webasto VEVO Ser flere på finndel.no brukt men testet og kontrolert ok, ga selv 1500,- for min da var det varmer, eksos og slanger med. Om noen heller vil overhale for så å sette inn enhet så har jeg en som ihvertfall har defekt glødeplugg.
Plukke treskeverket fra hverandre da.
Dårlig med garanti på en bil som har rullet 300`+
jupp ikke noe voldsomt enda men har begynt.
Hei alle sammen. Har en 2013 S-Max med webasto, denne har i den siste tiden begynt å ryke litt hvit (Brenner Frostveske). Jeg antar det evnt er snakk om brennerenhet, noen som vet hva prisen er på en slik. Evnt lar det seg kun å skifte pakninger ? Noen evnt vare nr hadde vært toppers Setter stor pris på tips
Fikk særdeles god rabatt hos Bilia 30% 1650,- veil betalte 1250,-
Bekreftet var sirkulasjons pumpa. Flott at alle reservedeler er så billig :S
Her en 2012 S-Max hvor jeg har fått fikset Webastoen. Men nå som den snurrer og blir varm så kommer det ingen varme i kupeen. Jeg mistenker at sirkulasjons pumpa til kjølevannet ikke går, noen som vet hvor denne sitter ?
Bytt stol til en med isofix. unga vil gjerne sitte i mitten når vi er ute og kjører. Men fyller opp alle andre seter i bilen før jeg setter noen i mitten.
vil ikke anbefale barn å sitte der. Beltet kommer veldig høyt og lite praktisk. 2013 så bør vel bilen ha Isofix
Ville absolutt hatt dieselvarmer. Denne vil og fungere som en hjelpevarmer for motoren når det er kaldt...
Hei noen som vet om det går og ettermontere ryggekamera til den orginale naviskjermen. Den har varsler foran bak men pipinga driver meg til det glade vanvidd og jeg liker og se bak bilen.
Kjøp en fra en Volvo V70N Same shit bare solgt løst
Mye fine biler her. Her er min så langt. Ikke avbildet med aluhjula som sitter på nå.
Hei noen som vet om seter i stasjonsvogn og hatchback går om hverandre ? Jeg har 2 veis el seter, men skinnsetene er 8veis. Nye ledninger eller er det slik som på volvo at stolen kun trenger strøm og hjernen sitter på stolen ? Forstolene antar jeg passer men det er bak jeg er mest spent.... de har begge 60/40 deling
Som emne sier så lurer jeg på hvor jeg finner ut hvordan finner jeg ut hvilken utstyrspakke jeg har sjekka www.etis.ford.com men står ikke der.
Hei alle sammen. Har et sett med Hertz ECX 165.5 210W som ikke er tatt ut av esken som jeg vurderer selge eller eventuelt bytte. i http://www.bilradiospes.no/m/shop/?produkt=107&katid=169&id= Her er spek på mine http://www.elutstyr.no/hertz-energy-ecx-165-5-2-veis-6-5-coaxial-hoyttalersett-par.html En eventuelt salgspris blir 800,- Aldrig åpnet esken engang da de egentlig skulle i en avensis som døde før de ble montert.
