WingDude Posted May 11, 2014 Posted May 11, 2014 Lurer på om det finnes en Ford mekaniker med god kunnskap om, og tilgang til IDS her inne, eller noen som kjenner til noen som kan svare på noen spørsmål vedrørende IDS ?
WingDude Posted May 11, 2014 Author Posted May 11, 2014 Spørsmålet gjelder Transit T350 2008, vet du om, eller greier du programmere en body module på disse bilene, med ei fil du får levert på en usb penn, eller lignende ?
grcossie Posted May 11, 2014 Posted May 11, 2014 Du får ikke endret data der, uten å logge deg på bil og lese av data som er der fra før. Litt usikker på om du har den muligheten i det hele på Transit
WingDude Posted May 11, 2014 Author Posted May 11, 2014 (edited) Hmm,limer inn noe tekst fra en epost fra et firma i England vedrørende dette, kjenner dere igjen fremgangsmåten ?-------------------------------Firstly we need to establish whether your van sucessfully allows the factory " as_built" file to be loaded "offline"If you download from the ford server your standard as_built file ( in .xml format ) & then try loading it into your BCM with your IDS unconnected to the internet.. the menu function is " retrieve as_built " .. tis will normally automatically download the required file but with your IDS machine offline, you will be promted to select the file you downloaded previously..In summary1- download as_built file in xml format from ford corporate server ( not .ab from motorcraft service )2 - In IDS locate the body control module programming menu 3- disconnect IDS from internet 3 - press retrieve as built to load the .xml as built file & follow on screen instructions to get that file into the van's BCM.Once that process is famililar & tested you can use the exact same method to load a modified as_built file, supplied by me.. Note that whenever you load an as_built file inot your BCM, user settable functions revert to default so locking behaviour, tire size etc may need re-inputting.. this is done via other menu funtions in the body control programming part of IDS.. Let me know any questions Edited May 11, 2014 by WingDude
Mondeo Power Posted May 11, 2014 Posted May 11, 2014 (edited) Ja dette er normalt men som grcossie sier så er det ikke alle modellene som har den muligheten / prossedyren. Transit 2008 har det vel om jeg ikke husker helt feil. Edited May 11, 2014 by Mondeo Power
grcossie Posted May 11, 2014 Posted May 11, 2014 Har aldri gjort det på den måten, men det kan sikkert virke det. Hva er det du vil åpne opp på bilen da?
WingDude Posted May 11, 2014 Author Posted May 11, 2014 Skal forsøke å få lagt inn cruisekontroll, ta en titt her http://fordtransit.org/forum/viewtopic.php?f=5&t=141692&hilit=cruiseHar fått tak i ratt, mangler et par kontakter fra en Transit BCM og en med IDS kunnskaper
Mondeo Power Posted May 11, 2014 Posted May 11, 2014 Fullt mulig dette, men det letteste er å få noen til å programmere dette i arbeidstiden.Ikke mange som får ta med seg ids`n hjem da den koster en arm og et bein.
grcossie Posted May 11, 2014 Posted May 11, 2014 Fullt mulig dette, men det letteste er å få noen til å programmere dette i arbeidstiden.Ikke mange som får ta med seg ids`n hjem da den koster en arm og et bein.Jeg låner en hjem av og til, aldri vært noe problem hos oss. Du får kjøpt kompl ids programvare og kabel på nett, for ca 3000,- Er helt lik de vi har på jobb, og med norsk tekst
WingDude Posted May 11, 2014 Author Posted May 11, 2014 Man får vel neppe tilgang til nedlastinger på de som ikke er tilknyttet Ford vel ?
grcossie Posted May 12, 2014 Posted May 12, 2014 Har bare prøvd en såvidt, var mer muligheter enn jeg hadde trodd. Kan endre as built data på de
Stian MH Posted May 13, 2014 Posted May 13, 2014 Er også fler muligheter med VagCom enn det greiene VW/audi bruker selv. Har hørt om flere av gutta på Møller som bruker Vagcom i enkelte tilfeller. [] 07 Audi A6 Allroad 2.7 TDi Q, kvartsgrå. [] 15 Ford Fiesta 1.0 Ecooboost titanium, candy blue [x]10 VW Golf 1.6 TDi shark blue "sommerblå"[x]11 Ford Focus 1.6TDCi Titanium, Candy Red[x]01 Ford Mondeo 2.0L GHIA, pepper red
