Hei lurer på hva slags diff dette er? 7 eller 7,5? Eller hvordan jeg kan finne ut, delenummer eller lignende?
Edited by k.larsen
Sitter "Tagen"(en liten blikkbit med nr på) så kan du sjekke det enkelt ellers så har Cosworth 108mm medbringere.
Sierra 1987-1993:
91GG 4006 ABA - AXLE ASY-RR LWHD & B 3.91 Sierra/Granada/Scorpio LSD typ 2
91GG 4006 GA - AXLE ASY-RR LWHD & B 3.91 Sierra/Granada/Scorpio typ 2
91GG 4006 AAA - AXLE ASY-RR LWHD & B 3.36 Sierra/Granada/Scorpio LSD typ 2
85GG 4006 DC - AXLE ASY-RR LWHD & B 3.92 Sierra/Granada/Scorpio typ 2
V87BG 4006 BAA/CAA/DAA - AXLE ASY-RR LWHD & B 3.62 Sierra/Granada/Scorpio LSD typ 2
V86BB 4006 AAA - AXLE ASY - RR LWHD & B RATIO 3.64 Sierra Cosworth LSD typ2
Sierra 1982-1986:
V87BG 4006 BAA - AXLE ASY-RR LWHD & B 3.62 Sierra/Granada/Scorpio LSD typ 2
Granada/Scorpio 1985-1992
85GG 4006 ACA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio LSD typ2
85GG 4006 AAA - AXLE ASY-RR LWHD & B 3.36 Sierra/Granada/Scorpio LSD typ2
91GG 4006 ACA - AXLE ASY-RR LWHD & B 3.64 Granada/Sierra LSD (Cosworth) typ2
91GG 4006 ADA - AXLE ASY-RR LWHD & B 3.64 64 Granada/Scorpio LSD (Cosworth) typ2
Granada/Scorpio 1992-1994
86GG 4006 AAA - AXLE ASY-RR LWHD & B 3.92 Sierra/Granada/Scorpio LSD typ 2
91GG 4006 ACA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio LSD typ 2
Scorpio 1994 – 1998
95GG 4006 AAA - AXLE ASY-RR LWHD & B 4.09 Granada/Scorpio LSD typ2
95GG 4006 ACA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio LSD typ2
96GG 4006 CA - AXLE ASY-RR LWHD & B 4.09 Granada/Scorpio typ2 different mounting bracket (koala)
96GG 4006 BAA - AXLE ASY-RR LWHD & B 4.09 Granada/Scorpio LSD different mounting bracket (koala)
96GG 4006 DA - AXLE ASY-RR LWHD & B 4.27 Granada/Scorpio typ2 different mounting bracket (koala)
96GG 4006 BCA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio LSD typ2 different mounting bracket (koala)
96GG 4006 BDA - AXLE ASY-RR LWHD & B 3.36 Granada/Scorpio LSD typ2 different mounting bracket (koala)
95GG 4006 AA - AXLE ASY-RR LWHD & B 4.09 Granada/Scorpio typ2
95GG 4006 JA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio typ2
95GG 4006 LA - AXLE ASY-RR LWHD & B 4.27 Granada/Scorpio typ2
Typ 2 means that diff got bolted driveshafts.
  • Like 1
Har plata kan legge ut bilde kan ikke si jeg så den koden som står på plata her men?
Kan prøve legge ved bilde her skjønte ikke så mye av hva som sto å kan ikke si jeg så noe som var likt?
Edited by Truckdriver
Unødvendig lang sitering.
Forcå finne ut om det er en 7 eller 7.5 tomms diff så leter du bare fram tommestokken.
Husker jeg rett så angir dette målet yttre diameter på kronhjul.
-200 Tahoe 5.3 LT, LPG drift.
Youtubekanal
