Div. Deler
clinton
selger div. deler.
- Sierra 87mod Henger feste
- List
- List under panser
- Rs vinge
- Escort Mk4 baklykter
- Escort luftfilter boks
- Ford flagg (stort)
- Rockford forsterker
- Alpine forsterker
Henger festet. Med 4 skruer til montering.
List
List under panser
RS vinge
Baklykter og luftfilter boks
Ford Flagg
Forsterkere..Den ene utgangen på alpine forsterkere vet jeg ikke om fungerer.
Den ene baklykten mangler en liten bit
Edited by clinton
89- 2wd cosworth ( 287hk/409 @ 0.9bar )
hvor mye for RF forsterkern??? info om den?
Description
The Rockford Fosgate Punch 501S slams your speakers with a one-two combination, so they deliver the high-end musical performance you demand.
125 watts RMS x 2 at 4 ohms
250 watts RMS x 2 at 2 ohms
500 watts RMS x 1 at 4 ohms in bridged mode
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-Way capable
requires 8-gauge power and ground leads and a 50-amp fuse wiring and hardware not included with amplifier
continuously variable 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
MOSFET power supply and output devices
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ noise-killing differential inputs that eliminate 80% of ground loop noise
Transana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD advanced protection circuitry for "intelligent" shutdown protection
wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
speaker- and preamp-level inputs
12-1/16"W x 2-3/8"H x 9-7/8"D
  • 4 weeks later...
Guest
