2L Ecoboost cratemotor med Controls Pack som bundle.
and
Ford Performance har lansert en cratemotor bundle til en pris på $5,995,- http://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=25303
The M-6007-20T Engine Kit kit includes:
  • EcoBoost Engine from 2013-2014 Ford Focus ST
  • Production rating of 252 Horsepower @ 5,500 RPM
  • Production rating of 270 lb. ft. of torque @ 3,000 RPM
  • When used with Engine Control Pack M-6017-20T and 93 octane unleaded fuel, torque is increased 90 lb. ft at 2800 RPM - with a significant increase up to 4200 RPM.  See the power curve for PN M-6017-20T
  • All-aluminum construction - about 25kg lighter than a comparable naturally aspirated V6 engine
  • Engine Kit Includes:
    • Starter
    • Alternator
    • Front accessory drive and belt
    • Intercooler and air intake ducting
    • Air Cleaner Assembly
    • Manual Transmission flexplate/flywheel
  • M-6017-20T Controls Pack includes:
    • Unique controls pack harness replaces stock body harness and is designed for custom built vehicle. Harness includes OBD-II diagnostic port to assist in vehicle calibration upload and problem diagnosis.
    • Includes PCM with Ford Racing performance calibration
    • Includes Electronic Throttle Control accelerator pedal, eliminating throttle cable routing problems
Hver for seg uten bundle mye dyrere.
motor http://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=22999
og Controls Pack http://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=22998
At det også satses på 4 sylinderen, og ikke bare V8 til bilbyggere er bra for resten av verden.
Kan dukke opp noen artige prosjektForder med motor på tvers, og på langs nå som man får en billigere måte å få seg en ny 2L Ecoboostmotor. Kanskje blir det noe å se på SEMA?
Som denne kombinasjonen:
2.0L Ecoboost engine swap to 86 SVO success!
2.0L Ecoboost engine swap, 16+lbs boost!
  • Like 1
Har vært mulig og kjøpe denne en stund, MDV har hatt den i webshopen lenge :D
http://shop.mdvse.com/itemfull.php?item=498&precat=Performance^19>Engine Components^106
Ja denne cratemotoren har man kunne kjøpe i en lengre tid nå til 8000 USD. Men det nye nå er at du får med Controls Pack sammen med motoren til bare 6000 USD.
Det er 2K USD mindre enn det kun cratemotoren koster alene. Og kjøper du Controls Pack til 2K USD senere så ble det regnestykket 8K cratemotor og 2K Controls Pack = 10K! :o mot denne bundlepakken til kun 6K.  B)
Det der er faktisk noe som kunne vært intressant å bytte ut cos motoren med!
Ja prisen er ikke så gal på denne bundle. Tror vi får se noe morsomt ut av dette fremover.
