Shelby Eleanor GT 500E/GT 500SS
HPL
Jeg lar først bildene snakke for seg, specs til slutt!
PERFORMANCE PACKAGE — GT-500E ($120,000)
Engine
Carroll Shelby Performance 427 aluminum engine
8-quart Canton oil pan
750 cfm Holley carburetor
NOS 125-horsepower nitrous system
Hooker headers
Transmission
T56 6-speed
Heavy-duty front and rear u-joints
Balanced aluminum driveshaft
30-pound SFI-approved flywheel
Tilton hydraulic clutch kit
Rear End
Nine-inch housing with 3.50-3.90 gearing
31-spline axles
Posi-traction differential
Steering
Total Control Products power steering pump kit
Total Control Products rack and pinion steering kit
Baer Tracker bump steer adjustable tie rods
Brakes
Front: Baer 13 x 1.1-inch Track System
Rear: Baer 12 x .81-inch Touring System
Slotted, cross-drilled, and zinc-washed rotors
Adjustable rear bias proportioning valve
Electrical
MSD Ignition Control
MSD coil
Trunk-mounted battery
Fuel
1/2-inch stainless fuel line
Electric fuel pump
Fuel Safe 22-gallon fuel cell
Exhaust
Hooker Super Competition Headers
Dual 2 1/2-inch exhaust with H-pipe
Walker DynoMax 2 1/2-inch mufflers
Cooling
Griffin cross-flow radiator
SPAL 16-inch electric fan
Chassis
Total Control Products outside weld-in subframe connectors
Total Control Products center section bolt-in kit
Total Control Products shock tower brace kit
Driveshaft safety loop
4-point roll bar
Suspension
Front: Total Control Products coil-over kit
Rear: Koni gas shocks
Traction Master traction bars
Rear anti-sway bar
Lowering blocks
Wheels
PS Engineering S/C Cobra replica
Front: 17 x 8
Rear: 17 x 9.5
Interior
High performance seats provided by customer
3-inch racing seat belts
Spesielt for GT 500SS:
SUPER SNAKE PACKAGE — GT-500SS ($150,000)
Shelby Vortex supercharger, 750 horsepower
Upgraded 6-speed transmission
Total Control Products suspension
Special Super Snake badging
1998 Volvo S80 - 231hk
jeg la ikke merke til dynamo reima før noen sa det :D
men det går en mustang som er veldig lik denne i drammens området...er visst til salgs den...andre som har sett den eller??
Nei, ikke sett...
MEN!!! Jeg vil ha den! :sikle:
Shelby Eleanor GT 500 er jo en klassiker!
Gone In 60 sec er basert på denne skjønnheten! :D
Den er altså ikke bygget for denne filmen! :D:D
Tror det panseret er sårt trengt!
Det luftfilteret der står rimelig høyt over motoren. Tror NEPPE et "vanlig" panser hadde funka! :)
ser jo ut som om de har glemt en hel hau med verktøy igjen oppå motoren ,og lukket igjen panseret jo... :lol:
88 Escort RSTurbo
Ja har sett den, går i sætre traktene... Ikke orginal men helt sinnsykt gjennomført bygd og MASSE power
flere som så på RIDES på discovery i går kveld eller?
et "firma" som bygde om en sliten fastback til en værtsing bil med en del eleanor-styling...var skikkelig med motor i den også...grom bil det
1982 Ford Capri 4.0 I6 turbo
1979 Ford Escort mk2 1600GL
Ålreigt Å Være Bilinterisert I Et Bilhatende Land
mens vi snakker om kjente film mustanger...noen som har sett/hørt om "bullit" mustang 390 GT...filmen fikk oscar og den har film historiens mest omtalte biljakt...(har film fra biljakta som jeg skal prøve å legge ut)
den på bilde har bare 2 pedaler, den i filmen har 3 ;)
så vitt jeg vet så er ikke d noe som heter Shelby Eleanor GT 500..
men en shelby cobra gt500 skall jeg gå med på...
eleanor er mer eller mindre et klenge navn den har fått etter film innspilling og bilen ser ikke sånn ut når den kom fra fabrikken, mark1 posta orginal bilde... Mener jeg så på RIDE`s på discovery en gang at de skulle bygge et par wanna be`s av eleanor...
Er ikke skrå sikker på dette, men er temmelig sikker på at det ikke eksisterer en som kom sånn orginalt fra fabrikk...
Edited by hår ball
Guest Taunus Basic
Klart den har tre pedaler den er MANUELL gir.. B)
Automatkassene tåler ikke sånn juling i lengden.. :P
Samme som Dodge Ram SRT V10.. Manuell gir på den også.. En skuffelse å høre den dra av sted.. :(
Caroll Shelby lagde ikke noen sånne glassfiberplastra Hollywood-utgaver av den ekte Shelby Mustangen.
På de ekte var det stål, krom, skinn og litt alu.. Resten heavy duty stuff...
Ikke dermed sagt at Eleanor er ufin.. Bilen er dritrå den.. B)
Blir varm andre steder enn i hodet av slike biler... ;)
